I need to make a copy of some mp4 (1080p and 4K) just for proxy use in adobe premiere because the original files are too heavy
and seeking is laggy in premiere. I have used Staxrip to make this files smaller and then edit them in premiere. Once editing is done
I then load the original file.
What I need is to find the fastest possible way to achieve this as the output quality has no importance for me. My question is what
encoder x264, x265, NVidia etc can give the fastest result? what settings make it the fastest and is there anyway to have the decoding
(Reading the file) is a fastest way? In all I need is to achieve max possible speed with no consideration for quality.
@SET x264opts="qp=16:qpmin=8:level=4.1:ref=0:bframes=0:no-chroma-me=1:subme=2:open_gop=0:keyint=1:pic_struct=1:aud=1:force_cfr=1:cabac=0:no_psnr=1:no_ssim=1:colorprim=bt709:transfer=bt709:colormatrix=bt709:stitchable=1:no-psy=1:scenecut=0:no-deblock=1:aq-mode=0" @ffmpeg.exe -y -hide_banner -v 32 -i "%1" -c:a copy -c:v libx264 -preset:v ultrafast -tune:v fastdecode -profile:v high -x264opts %x264opts% -x264-params %x264opts% -vf scale=iw/4:ih/4:sws_flags=spline+accurate_rnd+full_chroma_int+full_chroma_inp:out_color_matrix=bt709,format=pix_fmts=yuv420p "%~n1_.mp4"
The fastest (and best) way to do it is directly in Premiere. It will take your clips, load them into Adobe Media Encoder, encode them as you wish (I recommend low resolution i-frame proxies such as 960x540 ProRes or DNxHR, I also burn in a timecode counter so there's no ambiguity about which version I'm looking at.) Premiere then automatically locates the proxies and you can switch between proxies and original footage at the click of a button.
https://helpx.adobe.com/premiere-pro/kb/ingest-proxy-workflow-premiere-pro-cc-2015.html
Enhancing low quality video
By heldervrf in forum RestorationReplies: 5Last Post: 21st Dec 2017, 16:12 -
Elgato hd60 low quality export
By Jackenpachi in forum Capturing and VCRReplies: 2Last Post: 1st Jun 2017, 03:22 -
solution to make low res video bigger without upscaling
By codemaster in forum Software PlayingReplies: 3Last Post: 31st Aug 2016, 12:41 -
Improve blurry low quality video into clear high quality video.
By Osram123 in forum Video ConversionReplies: 2Last Post: 4th Apr 2016, 01:48 -
Simple fast tool to make mjpeg out of jpg's ?
By nerys in forum Video ConversionReplies: 4Last Post: 10th Feb 2016, 18:27
