Hello Guys,
i m having hard time finding the best settings on handbrake GUI, to do a really simple task.
basically i have .mkv video, which i would like to hardsub (subs must be permanent, so burned in).
My goal is to keep the same quality of inizial video (ofc a bit less since i am hardsubbing it, so there will be a decode/re-encode), and keeping the same initial SIZE (around 700mb).
So far i tried a lot of time with different settings.
Looks like keeping mkv format is the best option, but i m struggling which can be the best options under the video tab for:
VIDEO;
Video Codec?
Framerete?
OPTIMISE VIDEO
Encoder Preset
Tune
Profile
QUALITY
constant quality RF
AVG bitrate
any help is appreaciate, thanks.
Why are you hardsubbing? Because your player cannot play soft subtitles? Then it probably also doesn't support all codecs. Find out what it supports first.
Hello Sneaker, i need to hardsub for other reason, mostly for video distribution, i don't need soft subtitles.
Try x265 10 bit with e.g. preset slower. Framerate "same as source", variable (constant if you need constant for some reason). Profile main10, don't set tune. Set 2pass average bitrate to the one of the source (find out source bitrate via MediaInfo "View"->"Text"). (Auto) Passthru audio if possible.
How to easily burn in/hardcode srt subtitles to mp4/mkv with VidCoder
By Baldrick in forum User guidesReplies: 65Last Post: 25th Jun 2024, 03:11 -
How to add srt to mp4 without video conversion with handbrake?
By hibbs in forum SubtitleReplies: 4Last Post: 18th Jun 2015, 23:49 -
Please help me burn in subtitles to mkv rip of blu ray (handbrake)
By jimbanville in forum SubtitleReplies: 6Last Post: 23rd Jan 2015, 18:41 -
Please help me burn in subtitles to MKV rip file of blu ray (mkv/handbrake)
By jimbanville in forum Blu-ray RippingReplies: 1Last Post: 23rd Jan 2015, 09:45 -
Convert dvd to MKV with good quality - Handbrake settings
By Spy_br in forum DVD RippingReplies: 1Last Post: 17th Jul 2014, 18:22
