basically for space on my hard drive ive been encoding concert movies for use on PLEX..the video emcoding is pretty cut and dry no issues...but the audio end with AAC is really starting to irritate me with Handbrake...i use handbrake to convert both video and audio..but i have realized that Handbrake uses a new AAC encoder or has been for a few years now and its flaw is it crashes at high peaks whereas the old AAC encoder (Nero Encoder) is not around anymore that i could find outside of mediacoder...so ive been taking these concert movies and converting them in Handbrake (x264 L4.1 3500 kbps mp4)and passthrough on the audio but the problem use the audio is usually LPCM where handbrake cant pass it through so i have to convert to AC3 and then convert to AAC in Mediacoder (i really want to keep using AAC as my audio)...please can i get a opinion or better way to do this
What version of HandBrake are you using? The latest HandBrake is based on ffmpeg, as is MediaCoder. There shouldn't be any difference in AAC encoding quality except on Mac where HandBrake uses the Apple AAC encoder which is commonly considered the best AAC encoder.
There is a user guide to compile HandBrake with FDK-AAC encoder (Fraunhofer) but it has not yet been updated to account for HandBrake >= 1.2.0. -
the latest version and im on windows..but this version is where i noticed it a lot..you hear a lot of wow and flutter...i read somewhere that the FDK one is bad too nut quote me on that
i think i may try that or i could try to doing the whole job with mediacoder and all its options...i think the AAC encoder has at least 15 different options to choose from including ffmpeg..thank you for your help
http://wiki.hydrogenaud.io/index.php?title=AAC
http://wiki.hydrogenaud.io/index.php?title=AAC_encoders
Apple AAC is probably wise choice but personally prefer "FhG" AAC.
FDK is 16 bit, fully integer and as such acceptable/recommended for portable/mobile target but suboptimal for HQ.
encoding audio by ffmpeg
By alkoon in forum AudioReplies: 15Last Post: 15th Jan 2017, 04:45 -
audio out of sync after encoding avstodvd
By tyson25 in forum Authoring (DVD)Replies: 2Last Post: 14th Oct 2016, 03:24 -
Getting subtitles and audio in sync after encoding
By Colek in forum Video ConversionReplies: 5Last Post: 27th Sep 2016, 06:17 -
joining any audio and video together without encoding
By uglijimus in forum EditingReplies: 9Last Post: 10th Feb 2016, 16:24 -
Help! Audio always out of sync after AVCHD encoding.
By pinokkio in forum AudioReplies: 13Last Post: 29th Nov 2015, 06:30
