Im trying to burn a dvd and the file wanted the dvd is 4.67GB in size, the dvd Im using is 4.3GB in size. Is it possible to reduce the file size to burn onto the dvd and keep the quality? If so how? Thanks in advance for any help
FYI - I'm using Windows Media Player
Do you want a DVD that will play in all dvd players?
What is the format of the file? If it's DVD compliant you may be able to transcode it in something like DVD shrink,
otherwise it will need a complete re-encode and authoring, try AVStoDVD
You're using WMP for what ? -
first is the "file" actually a dvd? does it have audio_ts and video_ts folders? if yes, the only way to burn it to dvd and not re-encode is to burn it to a dual layer dvd. if no, then run it through avs2dvd and have it create a proper dvd structure and size.
Wrong. As davexnet wrote, you can use DVDShrink to reduce the size of the DVD without re-encoding. It is true, however, that the quality is degraded, especially if you need to shrink much. But with some luck, it may be sufficient to compress some bonus video and the menus, and/or remove some useless audio tracks, to let the video of the main movie unchanged.
r0lZ - PgcEdit homepage Hosted by VideoHelp (Thanks Baldrick)
- BD3D2MK3D A tool to convert 3D BD to 3D SBS/T&B/FS MKV -
You don't mention that the file is DVD file format or video format. If it's a DVD file, currently most of the DVD rippers are able to do the DVD file downsize stuff. As for the video file, you need to resort to some video compressor software. You can have a check on the below top compressors recommended:
https://bit.ly/2x9b70v
https://bit.ly/2RwpQvM
change FPS FROM 120 TO 30 TO REDUCE FILE SIZE
By smokemake in forum MacReplies: 5Last Post: 25th Jan 2017, 10:45 -
How to reduce file size in CRF mode?
By ben45 in forum Video ConversionReplies: 10Last Post: 24th Aug 2016, 17:47 -
How to reduce mkv file size
By onlygk in forum Video ConversionReplies: 12Last Post: 25th Jul 2016, 22:36 -
1080i.h264-NX.ts file is 7 gb-- how to reduce size in Handbrake or other
By loninappleton in forum Video ConversionReplies: 5Last Post: 24th Sep 2015, 18:41 -
[Q] How to significantly reduce file size
By edd1234 in forum Blu-ray RippingReplies: 31Last Post: 10th Jun 2015, 19:13
