foobar2000's ReplayGain scanner uses the newer EBU R128 scanning method, which I think it a bit more accurate than the original ReplayGain method, although I still found the old method pretty good. Which scanning method do you use? Other than that, foobar2000 saves the same ReplayGain data to tags (although it uses ID2v2.3 tags rather than APE tags).
Once files are scanned it can adjust the volume on playback (enabled by default) or it can adjust the volume of MP3 and AAC losslessly as MP3Gain does, although it can adjust them inside a container too. It doesn't matter if the container also contains video. The ReplayGain options are all under the right click menu, except for adjusting the target volume, which is in preferences (the default options are probably slightly different to the screenshot below). Because it's not as visual as MP3Gain in respect to what it displays in the GUI after scanning, I created a Playlist View dedicated to displaying volume (in my case I only used Track Gain).
It doesn't save information for undoing any volume changes though, as MP3Gain does. I can't say that's ever bothered me.
If you want to try my theme I can upload it for you and you can import it into foobar2000, but you can use the ReplayGain functionality with any of the standard themes.
Downmixing AAC 6 channel to stereo with dialogue audio gain?
By vonsworld in forum AudioReplies: 4Last Post: 6th Dec 2016, 02:27 -
avisynth: how to Gain up image?
By marcorocchini in forum Newbie / General discussionsReplies: 10Last Post: 5th Nov 2016, 05:34 -
AAC Gain Normalizing to 0dB & Muxing with FFmpeg
By VideoFanatic in forum AudioReplies: 198Last Post: 29th Sep 2014, 08:34 -
tfm audio tool auto gain control
By mocarob in forum AudioReplies: 0Last Post: 20th Jun 2014, 21:45 -
Old AVI files, looking for a way to set the gain
By THRobinson in forum Newbie / General discussionsReplies: 12Last Post: 20th Apr 2014, 14:41
