Hi,
I am a newbie and new to this site, so please forgive my ignorance. I just scanned with a Wolverine MovieMaker Pro some old super 8mm films. They were taken at 18fps. I would like to telecine to 30fps for burning a DVD. I understand that Mencoder can do that job but I need some help in setting up the command line.
Many thanks in advance.
Daniel
Results 1 to 18 of 18
I went through that manual page and at the bottom it gives some examples but not for what I want to do. I would like to get a recipe, likely from someone who has done this kind of work.
Thanks. -
You can't telecine directly to 29.97fps from 18fps. You can only telecine to a max 150% of the original framerate (27fps in your case). You have to bring the framerate up to a minimum of 19.98fps before applying a telecine. That can be done in a number of ways. Retail DVDs usually create duplicate frames. You can speed it up to 19.98fps. You can interpolate up to 19.98fps.
I have, many times. All this is easy enough when using AviSynth. I have no idea about mencoder.I would like to get a recipe, likely from someone who has done this kind of work. -
So can I telecine first to 19.98fps and then to 29.97fps?
No. You have to first get it to progressive 19.98fps. You could do that with duplicate frames as the media companies do with silent films, but I wouldn't. I usually interpolate up to 19.98fps (roughly 2 additional frames per second) before then applying telecine. I don't use mencoder and don't believe you can do the telecining in it as it's not the standard 3:2 pulldown. It's 3:3 pulldown. You'd need DGPulldown to do that, available only for Windows and Mac machines (I believe, but don't hold me to that). If you're in Linux, you don't have access to all the video tools available for PC users on Windows.
I do have a windows machines (w10) - so I will download DGPulldown. Can you please tell me the procedure to achieve what I need?
Thanks -
No. I use AviSynth. Do you? I outlined three different processes and there are more. Which do you want to use? The simplest (but not the best) is to create duplicate frames to bring it up to 19.98fps before being encoded with the telecine applied afterwards to make a DVD-compliant M2V file.
You might be able to use AvsToDVD on it to make the DVD without having to learn anything new. I expect it'll add duplicate frames to bring it up to 23.976fps, but I'm not sure as I don't use the program. Maybe someone more familiar with AvsToDVD will chime in. I'd recommend you try AvsToDVD first and see if you like the results. -
start it up and open the preferences. On the Avisynth tab you'll see "hard frame rate conversion"
set to your choice as described above. On the video tab choose NTSC as the video standard - it's all
pretty much self explanatory. Save current preferences as default and OK out.
Drag your source into the window. Hit the little down arrow to the right of the Output button
and you can choose your output type. Do not choose muxed mpeg file unless your source has audio.
Hit start. The output and the project log will be in the "DVD Output" folder as per the preferences -
You gave me an excellent guide. I see a DVD structure done but I'm puzzled because the VTS_01_1.VOB has about the same size as the mp4 file at 18fps, shouldn't be bigger based on having interpolated frames?
Thanks -
No. Output file size has no relation at all to the input file size. It's entirely dependent on the bitrate assigned to it. If the bitrates of the two are similar (and thus similar sizes), it's purely coincidence unless there's a way to make the two the same within the program. As I mentioned earlier, I don't use AvsToDVD.
So, did it do what you wanted? -
OK - So this DVD structure is ready to be burned to a DVD, right?
You saved my life! -
If it's inside of a VIDEO_TS folder, yes. You burn using ImgBurn and nothing else.
Make sure you test it out first. Not the VOB file but the DVD. And it was davexnet that provided the guide you needed that put you over the top for this project. Good going! -
Trying to do the same thing using AVStoDVD and get the dreaded "Warning! Title 1 output Video duration (00:00:00) is shorter than expected duration (00:01:23)." I do not have sound, and I'm wondering if this could be the issue.
My log is below:
<6/18/2019 10:11:39 PM>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 1
DVD Size: 85/4450 MB (2%)
DVD Output Setup: DVD Folder
DVD Label: DVD
DVD Menu: No Menu
Output Folder: C:\Users\thegi\Videos
Delete Temp Assets Files: Yes
Delete Temp Working Files: Yes
Edit Command Parameters: Yes
Post Process Task: Show Progress Status window
PREFERENCES
MultiThread: 1
AVS Video Source Filter: A2DSource
AVS Audio Source Filter: A2DSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline16Resize
Frame Adjust Strategy: 0
FPS Hard Conversion: 2
PAL SpeedUp: 0
NTSC SlowDown: 0
Video Resolution: 0
Video Encoder: 0
Video BitRate Min: 2500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
Force FFmpeg for Long Audio: 0
DVD Audio Format: 0
DVD Audio BitRate: 192
Keep DVD Compliant Audio: 0
Normalize Audio: 0
Auto Delay Audio: 1
DVD Audio Language (Primary): EN - English
DVD Audio Language (Secondary): EN - English
DVD Subs Language (Primary): EN - English
DVD Subs Language (Secondary): EN - English
DVD Subs Font: Tahoma 16pt (240,240,240)
Chapters Interval: 5
Use Source Chapters: 1
DVD Burning Drive: E: HL-DT-ST DVD+-RW GU90N A1C1
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Unload ActiveMovie Library: 1
Adjust DirectShow Filters at runtime: 1
Save General Settings: 0
SYSTEM INFO
Processor Name: Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz
Operating System: Windows 10 (10.0.17134) 64 bit
User has Admin Rights: YES
Running with Elevated Privileges: NO (3)
Available Output Disc Space: 739 GB
AviSynth is installed: YES (release 2.6.0)
LAV Filters is installed: YES (release 0.73.1)
ffdshow is installed: NO
CODECS REPORT
H.264/AVC: Microsoft DTV-DVD Video Decoder
Xvid: Mpeg4s Decoder DMO
DivX 4/5/6: Mpeg4s Decoder DMO
Other MPG4: Mpeg4s Decoder DMO
DV: DV Video Decoder
MPEG1: MPEG Video Codec
MPEG2: Microsoft DTV-DVD Video Decoder
AAC: Microsoft DTV-DVD Audio Decoder
MP3: MP3 Decoder DMO
MP2: Microsoft DTV-DVD Audio Decoder
AC3: No Preferred Filter set
TITLE 1 SOURCE FILES
Video: C:\Users\thegi\Desktop\8mm\julie\sound\0035.MP4
Info: AVC - 9827 kbps - 1440x1080 - DAR 4:3 - 20 fps (CFR) - Progressive - 1:23 minutes - 1665 frames
[MediaInfoLib - v18.03.1]
AVISYNTH SCRIPT
DIRECTSHOW AUDIO MIXER OPERATIONS:
No LAV Filters mixer ON/OFF adjustment required at runtime
<6/18/2019 10:12:01 PM>
TITLE 1 AVISYNTH FRAMESERVING CHECK
Error! Title 1 cannot be frameserved by AviSynth.
Warning message skipped.
<6/18/2019 10:12:05 PM>
START VIDEO ENCODING OPERATIONS
Video Encoding Profile: FFmpeg CBR 1-pass
Target Video FileSize: 84.1 MB
Encoding Parameters: -i "C:\Users\thegi\AppData\Local\Temp\DVD_4_0035_1.av s" -threads 8 -aspect 4:3 -c:v mpeg2video -b:v 8500k -minrate 8500k -maxrate 8500k -bufsize 2000k -dc 10 -y "C:\Users\thegi\Videos\DVD_4_0035.m2v"
<6/18/2019 10:12:14 PM>
Process aborted during Title 1 VIDEO encoding operations.
Error Message: Warning! Title 1 output Video duration (00:00:00) is shorter than expected duration (00:01:23).
For Video issues troubleshooting see Help/FAQ/Video section.
Warning! AVStoDVD Project ended with errors.
Log file created by AVStoDVD Release 2.8.8
Got it to work, no reply needed. Had to change the title edit to uncheck Auto Video setup and I changed the video encoder to use the HCEnc 2 pass. Also changed codecs to use LAV for AVC and "other mp4" (don't think I needed that, but did it anyway). Been a while since I been on here, nice to see its still going!
Interlaced or telecine?
By gamjerr in forum Newbie / General discussionsReplies: 15Last Post: 9th Apr 2018, 20:11 -
how to Telecine in handbreak
By jamespoo in forum DVD RippingReplies: 9Last Post: 23rd Jun 2016, 11:37 -
Why inverse telecine or deinterlace?
By Justin832 in forum DVD RippingReplies: 3Last Post: 11th Sep 2015, 01:13 -
Telecine vs De-Telecine (Handbreak)
By rdeffley in forum DVD RippingReplies: 12Last Post: 5th Jan 2015, 02:58 -
Just a bad telecine or is something recoverable?
By newpball in forum Video ConversionReplies: 6Last Post: 17th Dec 2014, 12:53
