And ignore the fact that you hijacked the topic with your drivel about formatting. Complete with yt link.
And ignore any other comment that you conveniently choose to.
I have made my point now. And I apologise to the OP for contributing to off-topic comments. If you continue to do so in this vein I will continue to report you.
Results 31 to 41 of 41
bokehraton
I got out my Sony HI-8 TRV87 and noticed when in playback mode if you go to the menu there is a TBC option. If yours has the option the BMD Intensity Shuttle should work but I cannot garantee it. -
Try the old fashioned way.Connect the videocam to your TV and also connect a VCR to the TV,Then record to the VCR as you playback.Then disconnect the VCR from the TV and connect the VCR to your computer via a capture card.[SHOCK HORROR I use EzCAP]THis was always successful for me,until my Sony videocam went to tech heaven.
^^ A suggestion but not, IMO, a very good one. Putting the footage on to VHS will degrade the quality and I see no reason to do that via a tv output (if the tv supports it) since you could go direct from the camera to the VCR.
But even then it will not solve the OPs issues. For some reason he can not get his capture devices to work or atleast record video. It may be a setting he has overlooked or something more fundamental. Either way that is the root of the issue not the initial video source. -
if you still cannot get a picture,then in the win10 search box,type in reliability history and left click on the app.If there are any red flags,select view tech details on each one in turn.this will give you a page of info on each problem and use this to search for an answer,if available.
Also,in the search box,type in dxdiag and check your Directx pages for any notifiable problem. -
I don't see the question, surprised nobody asked.
Are you using Win10? If so, that could be part of the problem. It fights video capturing.Want my help? Ask here! (not via PM!)
Never had any problems with USb Live2 and 64-bit Windows 10 Home using AmarecTv (v3.10). Whenever I've tried Virtualdub or Virtualdub2 on the same system then I've only had the usual audio sync issues with the captured material. Huffyuv, Lagarith, UT Video, x264vfw and MagicYUV (free v1.2) all work fine.
would that little copy protect switch on the tape cassette itself
prevent the video from being captured ?? -
But isn't that a over-record protect rather than a copy protect.
But we have a respondent that has no issues with a USB-Live2 and Win10. I would have thought that properly written drivers would have over-written any quirks that an OS had. So maybe the OP needs to revisit Hauppauge and get the latest drivers.
Even so. I still do not see any response to my basic suggestion to use the provided utilities. That, in the very least, should proove that the hardware works. What we never know is if any other 'enhancements' have borked a perfectly good system. -
bokehraton,is this thread still active or is your oroblem solved?
Video8 Capture with Virtualdub/Huffyuv
By Genius in forum Capturing and VCRReplies: 8Last Post: 13th Feb 2019, 09:24 -
Video8 only black and white - different Video8 formats?
By michaelm in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 25th Nov 2018, 10:59 -
VHS and Video8 capture
By bjolester in forum Capturing and VCRReplies: 3Last Post: 8th Apr 2016, 02:32 -
Sony EV-C3 Video8 playback issues
By cray71 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Sep 2014, 02:35 -
Capturing sony 8mm video formats (video8, hi8)
By TheDrifter363 in forum Capturing and VCRReplies: 2Last Post: 16th Apr 2014, 11:19
