How are the stills created while the video is playing?
https://youtu.be/JERPkYyserA?t=38
Higher speed camera (so you can get clean stills).
Take 1 still frame every couple of seconds, overlay it, fading away. If motion of foreground/background is an issue, mask out everything except the object and overlay that instead. May need to also create a duplicate video of the orig recording but with object isolated (all except item is masked), so that you can put that at the top of the stack of overlays (so it isn't ever partially obscured).
What is this effect called?
By Anonymous754 in forum Newbie / General discussionsReplies: 17Last Post: 11th Jun 2018, 20:06 -
Best NLE you probably never heard of?
By sophisticles in forum EditingReplies: 5Last Post: 24th Nov 2016, 13:06 -
NLE for smartphone
By SameSelf in forum Newbie / General discussionsReplies: 9Last Post: 10th Mar 2016, 14:37 -
Davinci Resolve 12 NLE
By SameSelf in forum EditingReplies: 11Last Post: 7th Feb 2016, 10:16 -
What's this audio effect called?
By langf in forum AudioReplies: 1Last Post: 30th Apr 2015, 16:52
