Results 1 to 9 of 9
1. Open up Notepad.
2. Make the first statement the "read" statement which opens up your MP4 file.
3. Make the second statement something simple, like a resize statement.
4. Save the file with the extension ".AVS".
5. Open this AVS file in VirtualDub.
That should get you started. -
Or even more simple, just to make sure you installed AviSynth properly:
Create a text file but with the extension .avs. Inside have a single line:
Version()
Save it and open it in VDub using File->Open Video File. You should see a rectangle with the AviSynth version number on it.
Read the startup pages at the AviSynth site.
And if you'll be working with DVDs often, learn how to work with them and DGIndex and the DGDecode.dll and MPEG2Source in your AviSynth scripts by reading the docs included in the DGMPGDec package. -
Manono, do you remember me? Can you believe it's been so long I ----I just couldn't remember how to do any of this.
Here's what I don't understand about the creators of these programs (Virtualdub, Avisynth, etc.): Why can't they just have SIMPLE INSTRUCTIONS, then I wouldn't have to come here!!!
Have you done a basic Google search???
AVISynth Wiki
First entry in this Wiki: Your first script – A guide for total newbies. -
Sure. You insulted me and others multiple times in another thread, and for no good reason. Nothing's changed.
what exactly would you like the script to do to you file??
Another long time member banned. This place resembles that doom9 cesspit by the day.
Need help with AVISynth script
By duffbeer in forum DVD RippingReplies: 13Last Post: 8th Sep 2016, 16:05 -
Basic Avisynth Script Problem For Simple X264 Launcher
By sam1776 in forum Newbie / General discussionsReplies: 11Last Post: 16th Oct 2015, 06:51 -
Best possible AviSynth Script
By Suwadith in forum Video ConversionReplies: 31Last Post: 10th Sep 2015, 06:43 -
Avisynth script help?
By PeterNL in forum Newbie / General discussionsReplies: 6Last Post: 10th Dec 2014, 11:35 -
avisynth - How to write avisynth script for rgba overlay
By moelover in forum EditingReplies: 3Last Post: 13th Apr 2014, 12:24
