hello all im using a blackmagic intensity 4k for my vhs transfers and im very happy with the quality but i keep getting alot of video drop outs and black flashing screen when capturing ... do any of you know a better alternative that is better with analogue input please
thank you for your time
Results 1 to 11 of 11
i have a panasonic DMR-ES10 on my video chain but still getting the drop outs :/ and thank you for your reply
The BMD products work OK if you have a strong clean broadcast complaint signal. Most VCR and camcorders from Best Buy will not give you that for VHS tapes. The Intensity Shuttle needs a TBC more often then not. I use an Intensity Shuttle for playback but I use an ADVC 110 for capturing VHS tapes. You would expect a little better from BMD when you consider the price of their products.
You might do better with a cheap USB dongle and a chip dedicated to SD capture. Avoid EZCap.
thank you both for your reply's - i think i will be looking into an alternative
With or without TBC, Blackmagic has infamous known is with SD material.
But with a better card, you'll still need TBC.Want my help? Ask here! (not via PM!)
Audio drop outs, metallic noises, and pixelated artifacts during playback
By guy24s in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 19th Aug 2023, 07:05 -
is there software to determine moving object having frame drop or lag
By helpme101 in forum Capturing and VCRReplies: 16Last Post: 10th Nov 2018, 12:45 -
Solution for Mini-DV drop-outs during transfer?
By jonsm in forum Capturing and VCRReplies: 5Last Post: 22nd Aug 2016, 23:29 -
Identifying if file is drop frame or not
By TailG8R in forum Video ConversionReplies: 1Last Post: 14th Jul 2016, 22:41 -
VirtualDub - Drop Frame
By harky in forum Capturing and VCRReplies: 22Last Post: 12th Jun 2016, 11:25
