Hello,
I'm trying to sync an audio from my PAL DVD (AC3) to the video of an NTSC DVD (H265 inside mkv). In most cases I only need to speed up the video from 23.976 fps to 25fps via MKVtoolnix and sync one single Keyframe via Avidemux. I put that delay into MKVtoolnix and everything is in sync.
Now I have 2 problems:
1.) Sometimes I need to slightly adjust the audio, like stretching a small piece or adding silence to a black frame to get it in sync midway through the video.
My plan was to load the audio on Adobe Audition and edit it. Problem is, Audition does not support AC3, so I need to save the Audio as WAV I guess and later convert it back to AC3. What would be the best way/tool to do this?
2.) I also need to get the video in Adobe Audition but it also does not support mkv. My play was to convert the video (just for the editing process). Later I will muxx the edited audio to the original h265 mkv. Does that makes sense or is there a better way to work?
Thank you very much, and sorry for the newb questions.
Well, if you load the video into AoA Audio Extractor Basic, it'll save it as WAV audio for later use in an audio program. That's what I do. You can convert it back to AC3 or whatever later on, after the editing is done.
AC3 to WAV
Code:@ffmpeg -hide_banner -v 32 -stats -y -i %filename% -vn -sn -dn -c:a pcm_f32le -f wav "%~n1.wav"
Unable to convert audio to WAV format on MeGUI v2896
By jealousy91 in forum AudioReplies: 2Last Post: 8th Feb 2019, 17:07 -
Synching/Muxing audio-video with software like audition 1.5
By hyuma in forum AudioReplies: 3Last Post: 27th Oct 2018, 03:42 -
Extract audio from VOB - edit and re-author
By PurpleHaze22 in forum AudioReplies: 8Last Post: 28th Apr 2016, 16:05 -
premiere->edit clip in audition ->leave me lots of Audio Extracted wav
By rama in forum EditingReplies: 7Last Post: 2nd Apr 2016, 13:48 -
Cant convert DTS-HD MA audio to WAV
By monks19 in forum Video ConversionReplies: 12Last Post: 25th Oct 2015, 13:28
