I'm currently working in Premiere CS5.5 on a series of videos at 24fps that require lots of stock clips that have different framerates.
Usually, if a clip looks smooth in the timeline, I leave it as it is. If it's juddery, I intepret it as 24fps.
90% of the time that works, but I often get problem clips, usually 5/100 in an 8 minute video.
The last or second to last frames will hang or skip forward and back, or every fifth frame will be a duplicate etc.
Is this just the nature of forcing clips into a 24fps timeline or is there a surefire way to get a locked 24fps? Is it something that's fixed in later versions of Premiere?
I've tried rendering the clips separately a few ways, eg. putting a 25fps clip in a 25fps timeline and rendering to 24fps, and interpreting a 25fps clip as 24fps and rendering to 24fps... sometimes that works, sometimes not.
It depends what the cause of the "juddery" is in the first place . Then you fix the actual problem.
The examples you gave sound more like source issues
eg. When every 5th frame is a duplicate, you should decimate the duplicate, then it will become a 23.976p clip, and that will interpret to 24.0p perfectly
The skipping back and forth might be a decoding issue with long GOP . Try encoding it to an I-frame format then re-importing , then interpreting (or you can fix it before importing). -
I'll post some examples once I've recovered from this edit! I spent 3 hours at the end going through ironing out the framerate.
What's the logic behind IVTC of material with varying framerates?
By CursedLemon in forum Video ConversionReplies: 7Last Post: 14th Mar 2019, 21:10 -
Framerates of interlaced footage
By CursedLemon in forum Video ConversionReplies: 3Last Post: 9th Sep 2018, 02:10 -
srestore and framerates?
By killerteengohan in forum RestorationReplies: 11Last Post: 30th Jan 2018, 19:13 -
Why won't Aegisub transform the framerates?
By Kracov in forum SubtitleReplies: 5Last Post: 16th Aug 2016, 09:01 -
Do Pixar re-master/re-encode movies for different framerates?
By Mr.Bean915 in forum Off topicReplies: 1Last Post: 7th Aug 2014, 00:58
