I bought a VHS player to transfer old family movies to DVD. Every tape I have tried only plays for a few seconds and then shuts the machine down. I am definitely a newbie, don’t know anything about video. Thanks
Results 1 to 9 of 9
I suspect the tape player has a problem or the old VHS tapes are suspect. If this player is new (rarity nowadays) talk to the seller, but assuming it is used, see if the seller will provide some form of help.
VHS tape players use a light inside the unit to sense the tape leader (which is clear tape on the start and the end). If something is allowing this sensor to see light, then it will stop the tape. Make sure the case is in the proper place and if there is a window to see the tape while in the machine, make sure there is no light shining in the window. You could place a piece of paper over the window as a temporary light block. If the tape still stops after a few seconds, then there is a problem with the player. Could also try a new tape to see if it still does the same. -
If the tape is sticky due to age/humity, they will tend to completely stop the video head from spinning causing the machine to save itself by shutting down. This may or may not be your problem.
Stickiness is very rare with VHS tapes. It's most likely that the takeup reel is not turning. Run a tape with the cover off (you may have to dim the room lights) and watch what happens.
If the previous owner had trouble extracting a stuck tape, the method used to extract it may have upset the timing gears. This will cause all tapes to immediately eject. Fixing timing gears requires a technician, if that is the problem.
OP does not have a problem with premature ejection. "Every tape I have tried only plays for a few seconds and then shuts the machine down." This suggests a glitch during Play mode.
It can be an electronic or mechanic issue, sent it over for repair.
What is the exact brand and model of deck?
Some have known issues, and some are easy to resolve.Want my help? Ask here! (not via PM!)
Sections of tape won't play on JVC VCRs
By Username in forum Capturing and VCRReplies: 7Last Post: 16th Sep 2018, 02:40 -
vhs tape wont play picture
By kitchensira in forum Newbie / General discussionsReplies: 22Last Post: 27th Jan 2018, 21:11 -
Setting up SV-5000W to play an NTSC vhs tape
By Alan Taplow in forum Video ConversionReplies: 19Last Post: 4th Jan 2017, 12:54 -
Panasonic AG-1980 won't play a tape... it just ejects it
By syrist in forum RestorationReplies: 25Last Post: 15th Dec 2016, 06:25 -
VHS VCR loads tape when won't play/FF/RW
By Darryl In Canada in forum RestorationReplies: 3Last Post: 27th May 2015, 12:33
