I have been using SVCD2DVD for many years. The last time I used it was January 09/2019. Since then I have installed the Windows 10 major upgrade version 1809. Not sure that's the cause but the problem is when I now attempt to start SVCD2DVD it pops up the regular opening logo and then that closes but the program doesn't start. It does not produce a log file. Anyone have a clue what I should try or do?
Right click the program.
Try running with 'Administrative' mode
Also try 'Troubleshoot compatibility'
Look at 'Properties>Advanced>Compatibility' for other options -
Thanks for replying, redwudz. Unfortunately I had already tried ALL of those steps. I even tried putting mscoree.dll in the SVCD2DVD folder, which I saw was described as a fix for VOB2MPG not working. I may try to 'back off' the Windows 10 1809 upgrade if I haven't deleted some of the files required (I'm sometimes to quick at cleaning up stuff.)
Video details missing in Windows 10 after 1809 update.
By bizzybody in forum Newbie / General discussionsReplies: 12Last Post: 15th Dec 2018, 05:23 -
Last Windows 10 Update (April 2018) - MEGUI doesn't start anymore.
By Cunhambebe in forum Newbie / General discussionsReplies: 43Last Post: 21st Jun 2018, 03:57 -
Windows Update won't update
By joecass in forum ComputerReplies: 49Last Post: 31st Jan 2017, 05:38 -
mkvmerge gui crashes on start/won't start
By buck09 in forum Blu-ray RippingReplies: 7Last Post: 2nd Nov 2015, 00:43 -
Microsoft advises Windows 8.1 users to install Windows 8.1 Update 1 soon
By usually_quiet in forum ComputerReplies: 2Last Post: 16th Apr 2014, 15:19
