Hello,
If anybody could help it would be amazing, thank you.
I downloaded the file that was mentioned in the forum and changed the extension to dvd instead of txt. I made a new folder called Violet0000\Rubicon\ and placed the file in the folder . I then burned the folder to an empty CD-R. I did this two times on two separate discs but when I put it in the player it showed up as a data disc and then said there is no playable content....
I am a mac user (!), so I did all this on a MacBook Pro .... I burned the disc using an old Pro which has an inbuilt drive and burner. Do I need to make this cd on a PC instead ? I went into file info and changed the extension of the file to “dvd” properly ( I believe) because it prompted me to make sure of the change.
Many thanks !
The player is LG BP250. Recent new purchase. UK.
Results 1 to 12 of 12
You probably saved the downloaded file as a txt.file. The instructions tell you NOT to do this.
On my system you can change the file to .dvd BEFORE you save it and then you end up with a file of 4 bytes. -
Thanks for the reply!
(I THINK) I saved it properly as a .dvd after downloading it , because I went into the file info (command I) and changed it that way in “name & extensions” . It was definitely 4k.... it is a plain text document and if I open it , it only looks like it contains one single character....Does this sound wrong? ...I then created a new folder to put this file in and called it rubicon etc etc.
Thank you for your help. -
if you follow the instructions here - https://www.videohelp.com/dvdhacks?dvdplayer=LG+BP+250+&hits=50&Search=Search
it should work. -
Hi
Thanks for the reply.
Yes I have tried following the steps quite a few times already. It doesn’t seem to work for me. I downloaded the file, changed it to .dvd extension so that it becomes a ‘document ‘ instead of a txt file. I did this with command I and changed it in “name & extensions”
I then made a folder named violet0000 and a folder named rubicon , And placed the file inside the rubicon folder and the rubicon folder inside the violet0000 folder.
I burned the violet folder to disc
The disc shows up on my Blu-ray as a data disc. It shows ‘rubicon ‘ but tells me there is no playable content ...?
So my question is what dis I do wrong and how can I make it work? There must be a way if other people have figured it out... I am using a Mac. Does this matter?
Thank you. -
Like I already said. The saved file is NOT a plain text document. On my windows system I can only open it by forcing notepad to read it.
I do not know how this works on a Mac. In windows there are only two 'save' options after the download. 1) as a .txt file and 2) as 'all files' from a drop-down selector. The second one was chosen and after altering the file extension to .dvd I saved it.
(unfortunately the system will not allow me to upload this file as an attachment) -
Hi,
Thanks so much for your reply.
Yes I do believe I have saved it correctly . It becomes a “document “ on a mac after converting from a text file. It’s is a dvd extension, not a txt. I think the problem possibly lies in the way I have burned it.. not in the way I have saved it? If anybody has done this on a mac, any tips would be greatly appreciated! Thank you!
Kindest regards
Reading down the page from the link as referred to by october262 one respondent mentions the file system you should burn the CD as
ISO9660+Joliet Level 1 mode. -
Thank you very much for your advice.
Yes I saw that but I dont think it applies to me as a mac user. We don’t get given the chance to choose Such options in the first place. And Joliet is windows as far as I can tell. Which I guess is the frustrating thing about using a mac. The general user is not allowed to make changes to the way things have already been decided , it is all a bit “computer says no”. Almost like it’s the opposite of what Apple says they stand for - you are allowed to Imagine there is another amazing world out there.. .BUT .. only if it is their world and you must play by their rules...It is quite a controlled world.
Still, there must be a way to do this on a mac.....I will keep looking...
Thanks again! -
Well according to Wiki, MacOS will read Joliet so one would expect it to be able to write a CD using it.
But if this is peculiar to a Mac and you do not have access to a Windows system and a program such as imgburn that should create the proper disk for you then I suggest you create a specific topic about writing 1SO9660+Joliet in the Mac forum -
Ah yes thank you for the info! That is a great idea. I am going to do a bit more research first. Thanks again!
RCA RTB1023 region free code
By slayer23 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Dec 2017, 01:23 -
Sony region free code
By atrojoe in forum Newbie / General discussionsReplies: 27Last Post: 19th Jul 2015, 16:24 -
DVD region free code
By Beffydee in forum Newbie / General discussionsReplies: 3Last Post: 13th Feb 2015, 07:44 -
Philips DVP2880/F7 - region free code
By vidblue in forum DVD & Blu-ray PlayersReplies: 12Last Post: 30th Jun 2014, 08:40 -
Samsung BD F-5500 (E) Region free code
By lilt8311 in forum Blu-ray RippingReplies: 3Last Post: 20th Apr 2014, 17:01
