Adobe CC 2019
If you haven't made a time-code this is how then follow after this:
1. File/New/Transparent Video
2. Type Time-code into the effects search bar / Drag onto the new transparent video seq
Change the color on time-code
3. Type Change color into effects search bar / Drag onto the new transparent video seq
4. The following layout of the effect control should be set to the following under the change color fx
View = Corrected Layer
Hue = 0
Lightness Transforms = - 40 or -50
Sat Transform = 100%
Color to Change = Black
Matching tolerance and softness = 0%
Match colors = Using Chrome
Then play with the Hue transform and you can pick any color you like without effecting anything, you can also set color to change from one to the the other super effective and fast to do and edit.
Results 1 to 1 of 1
Change subtitle color on a Mac
By okizen in forum SubtitleReplies: 4Last Post: 13th Oct 2018, 04:28 -
Subtitles Change Color
By lomaidala in forum SubtitleReplies: 5Last Post: 18th Jan 2016, 16:09 -
Lagarith lossless codec / Adobe Premiere color problem
By Woncler in forum EditingReplies: 3Last Post: 7th Jun 2015, 16:58 -
How to maintain subject color but rest is b/w in Adobe Premiere Elements 11
By AAC in forum EditingReplies: 1Last Post: 17th Jan 2015, 08:21 -
Color change after encode
By Tylerr in forum Video ConversionReplies: 8Last Post: 7th Jan 2015, 07:31
