Page 2 of 2
FirstFirst 1 2
Results 31 to 53 of 53
  1. Capturing Memories dellsam34's Avatar
    Jan 2016
    No, the 704x480 already accounts for that.
    I see.
  2. Banned
    Dec 2010
    New York
    I swear, this is the crap that takes all the fun out of video editing. I think I'm going to just pay someone to do my project for me instead of wasting time reading a bunch of sh__t that I have no knowledge about.
  3. Capturing Memories dellsam34's Avatar
    Jan 2016
    Yes that's exactly what you need.
  4. Originally Posted by unclescoob View Post
    ...I mean it won't even open my mpeg-2. But...um....I thought this was the whole point of virtualdub, to open MPEG-2s.
    Virtual Dub never opened VOBs/MPGs. Most people use AviSynth scripts and MPEG2Source to open DVDs in VDub. If you want to open MPEG-2 video in something, then use the newer Virtual Dub 2. It opens most kinds of video directly.
    That statement really is an oxymoron.
    I've almost never found editing to be fun. Restoring, sure. Conversion, sure. Watching, definitely. But editing is akin to a visit to the dentist's office (and you don't even get the consolation prize of having a cute dental assistant).
  6. Originally Posted by dellsam34 View Post
    480 includes head switch lines, Vertical burst, Caption, Macrovision ...etc, All that junk is included in the 480 lines, otherwise it wouldn't be captured with the capture card. So the active video frame is about 702x460.
    Nope, nope, nope.
    480 does not contain that, ever wonered why the 525 line NTSC was always 480 lines in digital realm? Well now you know, 480 is the image, the rest is the rest you metiones. Similarly 625 and 576 in PAL.
    And it's lovely that people still know the tricks of analog capture, especially not to resize 720 to 640. And those additional pixels are called nominal analog blanking.
    The ITU (cannot remember number) that specified digital SD television with backwards compatibility with analog specified the length of the scanline as 53,333... µs, in PAL the actual image is in 52 µs, in NTSC it is a fraction more, thus when sampled at standard 13,5MHz, the 53,3 µs results in 720 samples, while the active 52 µs comes as 702, similar to NTSC.
    Thus, never trust people who use 1,067 PAR. Never trust VLC that will play 720x576 as 768x576, or worst of all 720x480 as 720x540 stretching vertically...
  7. Originally Posted by SF01 View Post
    Nope, nope, nope.
    Nice try. jagabo was not replying to that particular quotation from dellsam34. Did you just sign up here so you could intentionally mislead everyone and spout common knowledge as if it were some sort of a revelation?
  8. Originally Posted by manono View Post
    Nope, nope, nope.
    1. I registered over a year ago.
    2. I was replying to the false statements about what is included in the 480 lines.
    3. What that I have said was misleading?
    4. I have already read a lot of forums, guides and articles ranging from the 80s to most recent, believe, that is NOT common knowledge for some people, if it is for you, then good for you.
  9. https://www.adobe.com/devnet/flash/learning_guide/video/part06.html
    For NTSC video images, the SMPTE 259M professional standard specifies that the 525 lines be represented as 720 × 486—that is, 720 horizontal pixels by 486 vertical pixels. This default video size is commonly known as D1. Capturing footage with most modern video capture cards from a professional BetaSP or Digital Betacam source results in a D1-sized frame. Capturing footage from a DV (digital video) source, however, yields a 720 × 480 frame. The difference between the D1 specification and the DV specification is only 6 vertical pixels.
    The D1/DV NTSC and PAL specifications specify non-square pixels (often called D1 aspect ratio), while computer monitor pixels are square. In fact, DV/D1 NTSC pixels have a 0.91 pixel aspect ratio (PAR), which means they're tall and skinny; DV/D1 PAL pixels have a PAR of 1.09, so they're short and squat. For this reason, when you look at a D1 video image on a computer monitor, the images appear to be distorted (see Figure 1).
  10. Originally Posted by babygdav View Post
    Other than Betacam everything else uses 480, DV, DVD, etc. But 486 was originally intended.
    And I was earlier reffering to the ITU Rec. 601.
  11. Originally Posted by SF01 View Post
    You included two quotations from different parts of the thread that had no relation to each other. Here's what he was responding to:
    There is also extra pixels captured on top and bottom of the screen that are not part of the actual video frame which makes up for that horizontal 2% stretch.
    The 720x480 capture doesn't include any of the information above it. And I apologize for thinking you had signed up just for this. I forgot it was 2020 already.
  12. 1. If one wants to create a perfectly legal, based on specs, digital ntsc file, the you'll need to use the horizontal resolution of 720 pixels.
    Yes, you can play 640x### etc resolution files on any device that outputs to the tv or monitor that file full screen (by stretching or shrinking it to fit), but just because you can play a 240x resolution file full screen ntsc doesn't mean it's a legal to specs file.
    2. 486 or 480?
    Not much you can do about that.
    dv to ntsc and you'll either have black lobes above and below, or a forced stretch.
    Broadcast ntsc to dv and you'll either have lines cut off top and bottom, or a squish.
    So, pick based on the expected output you'll use.
    E.g.. If you're outputting to pc monitor, phone, and dvd, simply use 720x480 rather than 720x486 which is used for broadcast.
    Yes, annoying when standards bodies can't decide on a standard ntsc resolution.
    3. If you're capture from the digitizer is not a standard size, eg 640x480, it's not a standard resolution.
    You can get software on the pc to display it correctly (force 4:3), but it is not the resolution you'll need for other devices.
    E.g.. Drop that 640x480 onto a dvd and the software will either maintain 1:1 pixel relationship by centering it on black 720x480, or stretch pixels to make 640 pixels fit the 720 width.
    IF the software is smart enough, the aspect ratio will be retained and all is good. If not, it'll look stretched and you'll have to process the video yourself beforehand.
    4. 640x480 with black edges.
    Not much you can do about overscan captured on these consumer devices. If you go vhs to dvd (on double drive recorders), or into dv/hdv (either two decks or into a camcorder with analog input), the edges are usually cropped and you'll get a full picture.
    Not always since that's the nature of analog input formats like vhs.
    5. If you crop but don't change the resolution by stretching, eg640x becomes 625x after cropping, you'll likely have to manually calculate the aspect ratio for the video player to display it correctly.
    The video player may be very confused - is this a 1:1 ratio video file? 4:3 but you're feeding me fewer pixels than expected?? Etc
    6. Ideally, you can adjust the size of the input to fully fit without black and the resolution of the capture (720x480), but if you've got 640x480, black, then you'll need to feed through virtualdub, crop, resize to 720x480 and embed 4:3 aspect ratio flag to be absolutely "proper".
    Unfortunately, the resize does alter the quality, so this may be bad for your desired final output.
    7. The solution is to recapture everything to a device that outputs 720x and where it either properly crops black entirely, or you can adjust the overscan area manually (broadcast equipment).
    Then, you'll get what you want with good 1:1 pixel capture and quality from the original with no further stretching or cropping to mess up the image.
    Such devices include the Canon hv10 and newer HDV tape camcorders that have analog input, or better, the Canopus avcd 100, 110, 300....
    https://m.youtube.com/watch?v=JhoO5eVzVQA
    https://www.google.com/amp/s/www.bhphotovideo.com/c/product/349146-REG/Grass_Valley_60...erter.html/amp
    Or dual deck dvd vhs recorder like the Panasonic ez47, then rip dvds to pc into mpeg-2 files.
    Hdv file format > dv file format > mpeg-2/dvd file format for capture quality from vhs tapes.
    For your 640x480 captures, leaving it as is and merely making sure it has the proper display ratio flag is the least destructive way to maintain the original source quality. At this resolution level, stretching pixels through resampling isn't good at all - not enough pixels to make anything look good, only worse.
  13. Originally Posted by manono View Post
    This is the quotation I was reffering to:
    The fact that it was nested was because I didn't accouns for the fact that someone might think I was reffering to the quote within the quote.
    The 480 lines contain active image only, no "head switch lines, Vertical burst, Caption, Macrovision ...etc", which I believe I have said then and there.
    Yes, but only when you need an NTSC file, it's good for archive, burning DVD, etc, but for the internet (youtube especially) one has to convert to square pixels, both PAL and NTSC.
  14. Originally Posted by babygdav View Post
    Nonsense. Do you just make this stuff up? I make 704x480 NTSC DVDs all the time. Maybe you had better read the What is DVD section of this site.
    NTSC (NTSC Film)
    Video:
    Up to 9.8 Mbit/s* (9800 Kbit/s*) MPEG2 video
    Up to 1.856 Mbit/s (1856 Kbit/s) MPEG1 video
    720 x 480 pixels MPEG2 (Called Full-D1)
    704 x 480 pixels MPEG2
    352 x 480 pixels MPEG2 (Called Half-D1, same as the CVD Standard)
    352 x 240 pixels MPEG2
    352 x 240 pixels MPEG1 (Same as the VCD Standard)
    29,97 fps*
    23,976 fps with 3:2 pulldown = 29,97 playback fps (NTSC Film, this is only supported by MPEG2 video)
    16:9 Anamorphic (only supported by 720x480)
    I didn't bother to read the rest of what you wrote. You just talk people into submission.
  15. Originally Posted by manono View Post
    http://www.mpeg.org/MPEG/DVD/Book_B/Video.html
    When I talk about NTSC, that is broadcast (over-the-air) TV standard resolution.
    DVD standard is not a NTSC broadcast standard, so it specifies and allows many more resolutions, including 704x and lower.
    A NTSC DVD is merely mastered for correct playback on NTSC TV sets and players, not for NTSC broadcast.
    I'm talking about NTSC, broadcast-safe (ready/ formatted correctly / to specs) resolution:
    https://en.wikipedia.org/wiki/Broadcast-safe
    Thus, 720x (although it does allow 640x if you take out overscan information, etc).
    Now, analog broadcasts don't have pixels - they are continuous analog signals. There is the concept of scan lines, but no concept of an individual pixel.
    Rec. 601 defined the digital "equivalent" of such worldwide, and it's been the standard in use for the transition of standard definition analog to digital.
    https://www.itu.int/net/ITU-R/index.asp?category=information&rlink=rec-601&lang=en
    Again, 720x is specified and is compliant with both the NTSC and Rec. 601 standards.
    Pretty much all SD devices in broadcast use 720x, so while 640x might be legal, it's not the de facto standard.
    740 vs 704 = 5% less data/picture information/detail recorded.
    740 vs 640 = 15% less detail recorded.
    While you can certainly capture VHS tapes to 640x, why if you can use 720x? You gain an additional 15% in detail (roughly since it's not exactly more pixels equals more details), so it's a better analog to digital conversion.
  16. Video Restorer lordsmurf's Avatar
    What spec?
    DV? Sure (but NTSC only).
    Pretty much anything else? Nope.
    Uh ... what? No. A "monitor" or "phone" is 1:1, and there is no "DVD". (DVD-Video specs, yes, but "DVD" no.)
    Huh? That statement makes no sense.
    What software?
    What exactly is a "DVD" in this context. Just data on a disc? DVD-Video?
    ... and I just quit reading. Nothing in your post makes a lick of sense.
    Nope, nope, nope.
    Congratulations. You're confusing analog "lines" with digital resolutions. But the numbers are NOT related.
    FYI, that's the same sideways logic that, 20 years ago, had people parroting the myth that "VCD = VHS quality", all because VHS has "240 lines" and VCD was x240 (NTSC). What's even dumber is that those numbers reference different axis.
  17. Originally Posted by SF01 View Post
    Nope, nope, nope.
    FYI, that's the same sideways logic that, 20 years ago, had people parroting the myth that "VCD = VHS quality", all because VHS has "240 lines" and VCD was x240 (NTSC). What's even dumber is that those numbers reference different axis.[/QUOTE]
    Yeah, more or less, that's rather my thought abbreviation reffering to the active image in the scan lines. I might have incorrectly used the specific terms reffering to analog lines and digital resolution. And I have never considered VCD to be an equal of the VHS, VCD's best use is as a beermat, I'd rather be watching and rewinding VHS.
  18. Capturing Memories dellsam34's Avatar
    Jan 2016
    Maybe video capture cards are not alike:
  19. Formerly 'vaporeon800' Brad's Avatar
    Apr 2001
    Vancouver, Canada
    The technical definition of "active video area" doesn't exclude head-switching noise as you've marked.
  20. Capturing Memories dellsam34's Avatar
    Jan 2016
    I know, that was the definition of someone here that I was responding to with a picture.
  21. Originally Posted by dellsam34 View Post
    Top and bottom overscan is still not blanking, it still contains picture information, the head switching noise depends on the VCR that was used to record and the VCR used to play back tape. I will almost always appear, but with proper equipment it can be heavily minimized, I sometimes get results of max shift of 10-20 pixels, worst tapes I've seen were like your attachment. The signal coding ends at the last line of image and then are the non-image signals that are perfectly represented on the image that captured the RF signal and processed like the LD RF capture described here: https://www.domesday86.com/?page_id=978
    Now the "usable and watchable" part of the image is something else entirely.
  22. Video Restorer lordsmurf's Avatar
    What is "proper equipment"?
    Head-switching noise is two-fold. The playback VCR, and the source tape. The noise is an interaction between these two things.
    This is why some tapes are excessive, and others not, even on the same VCR.
    Yes, you can reduce it in the VCR, but it's often simply a matter of calibrating the alignment and heads. There is no "proper equipment" to speak of, unless you're just referring to using another VCR entirely.
    The noise profile is different not just brand to brand, or model to model, but unit to unit of the same brand/model.
    And overscan is part of the active picture.
    It's in the overscan anyway. Mask and move on. It's not worth discussing unless size exceeds the overscan area.
  23. Originally Posted by lordsmurf View Post
    That's basically what I had to say.
    The best results I have seen were 2-3 lines of noise and the most bottom part of the image was as stable as the main image. If one has lots of spare time and patience it's not impossible to align them maually for each frame.
    This is an example of what I squeezed out of ordinary VHS-C:
    https://www.flickr.com/photos/86162958@N05/49361002048/
    2 rows of pixels make up the whole head-swithing noise. And with some deinterlacing it disappears most of the time.
    But the main reason it might look better is because it's PAL.
    And I completely did not notice this:
    NTSC (NTSC Film)
    Video:
    29,97 fps*
    704x480 is possible, the analog blanking is just added, when converted to analog signal, but it's not full D1. Like I said, I'm not really as familiar with NTSC as I am with PAL.
    If you don't bother, then don't bother even discussing.
    Show me please an example, where I "just talk people into submission".
