I pay for online streaming of tv chans from my provider. They have a clunky web browser streaming with adobe flash which isn't very stable, so I wanted to try to use vlc to stream instead.
It looks like they are using HLS for streaming. I think it might be encrypted because when I use chrome webtools to find out the ts file, I can download it fine but when I try opening it up in vlc, it doesn't play and mpc-hc says 'cannot render the file'. I've also tried the Adobe HDS/HLS video saver chrome extension, but that results in the save unviewable video. Has anyone come across a similar streaming setup with their provider and any way around this to use 3rd party programs like vlc to view the stream?
If you are paying for this service then there is no difference to any other subscription based service such as Netfilx, Hulu etc.
So, essentially, discussion contravenes forum rules.
Even so, using a third-party viewer is not going to improve unstable, buffery reception which could be server congestion, connection speed, or even a combination of both. -
Try streamlink - a CMD tool.
Run:
That will result opening the VLC and playing it. If the picture is greyish and no sound - yes it's encrypted.Code:streamlink "http://url.to.m3u8" best
Also possible that need to pass cookies to console to open the stream too.
For full picture a link to embeded stream would be great,but if it's a subscription site with authorization required then as the person above said - it violates the forum rules.
Stream Manoto via VLC
By Mumba in forum Video Streaming DownloadingReplies: 4Last Post: 17th Sep 2018, 12:20 -
Android:i want to play this channel in vlc android application (vlc.apk)
By sam jack in forum Newbie / General discussionsReplies: 5Last Post: 16th Oct 2017, 16:10 -
5.1 AC3 audio.. no sound from left channel in VLC or mpv, fine in Audacity
By arcooke in forum AudioReplies: 1Last Post: 26th Dec 2016, 02:53 -
how to pause m3u8 stream in VLC?
By david151 in forum Video Streaming DownloadingReplies: 0Last Post: 12th Jun 2015, 15:40 -
HLS stream VLC 2.13
By PrinzEugen in forum Video Streaming DownloadingReplies: 7Last Post: 13th Jul 2014, 05:11
