I am looking to buy a new all-in-one printer. I am thinking if I should get a color ink-jet or a black and white laser. I occasionally print photos, but I think the cost of ink and the need to replace the cartridges every a few months, is not really worth it. I have been using Canon printers for years, but I have had enough of them.
				Results 1 to 30 of 36
	HP has an Instant Ink auto reorder program which I believe saves a few bucks. We never signed up because we don't use that much ink but at the time I thought it was beneficial for heavy ink users. If you print on CDs/DVDs you can't go HP. I believe only Canon & Epson have that function. Good luck.
	I would go for an all-in-one laser printer,ink dries up if not used much while toner lasts for a long time. I think,therefore i am a hamster.
	Get a color laser printer,i just replaced the toners after 5 years in my color laser printer. I think,therefore i am a hamster.
	Some of the choices I have are SAMSUNG XPRESS SL-C480W and HP COLOR LASERJET PRO MFP M180N T6B70A. Can I use compatible toners with these?
	I have a Samsung clp-320 color printer and it has no issues using compatible toners i bought from ebay.I would stay away from HP since they load tons of other software not needed. I think,therefore i am a hamster.
	I've printed a few photos and the results were very good. I think,therefore i am a hamster.
	How about an Epson Inktank printer. About the same price as a laser but way cheaper to run. https://epson.com/For-Home/Printers/Inkjet/Expression-ET-3700-EcoTank-All-in-One-Super...r/p/C11CG21201 . When I get setup in my new house this is what I'll buy,
	I wouldn't say that printer is way cheaper to run,get a 1000 prints and replace the toners for $60 total and the color laser printer itself is about $150 on sale. I think,therefore i am a hamster.
	The best AIO is not to get one at all. Been there, made the mistake already. Those things are crap.
 I've printed color photos, that are on my wall, using my Minolta color laser, and these look far superior to inkjet. Minolta isn't made anymore, but my point is that color laser can look outstanding, from the right company, and the right model. Not HP, HOP is overpriced low-quality junk.Want my help? Ask here! (not via PM!)
	I agree with lordsmurf,any AIO is always crap,better to get a good laser printer and a separate scanner,ink will dry up on you and with that much ink in the epson i shudder at the issues. I think,therefore i am a hamster.
	I just do black and white laser, and then use online companies to do any color printing which then mail it to me. Cheaper for my needs.
	Owning and using Brother DCP-L2560DW, all types of interfaces (WLAN, ETH, USB) - can't say anything against this machine, neat, compact, work fine, stable driver. Can be operated with or without PC. Personally i think about buying additional colour laser printer but from second hand market (and less SOHO, more serious office type).
 Never recommends ink type as they require special paper to deliver best results and also on long time line are more expensive...
	i've never seen a printable cd or dvd that says it's for laser printers. printables have surfaces to absorb liquid ink. --
	i've had years of good luck with my all-in-one, cd/dvd printing included canon mg7520. no longer made but i saw a newer canon recently on amazon for $70 that looked ok. ts9120 or something. --
	[QUOTE=aedipuss;2545819]i've had years of good luck with my all-in-one, cd/dvd printing included canon mg7520. no longer made but i saw a newer canon recently on amazon for $70 that looked ok. ts9120.
 I have that printer also, I am just now trying to figure out how to print on a DVD but that Canon Garden program is a pain in the ass.
	I have been advised not to get an Epson because of ink getting dry if the printer is not used often. How accurate is this statement and how often would I need to print to avoid such a problem? I don't want to buy an ink tank printer that costs as much as a laser, but I am tempted by the Epson EcoTank L3050 which I found on offer. Does anyone have experience with this?
	You need to print at least one paper per week,if you don't print for a month+ there's a good chance the ink will dry and clog the nozzles. I think,therefore i am a hamster.
	What about a black and white laser? What all-in-one printer would you suggest for home use? I would prefer a duplex printer, but I have seen that they are much more expensive and probably not worth the cost. I have been using an HP at work and never had a problem, but I admit that I usually print less than 100 pages every week.
	Every Epson inkjet I have owned would drain more ink during "cleaning cycles" than on actual printing. I've had a color laser printer for almost five years and have only replaced the black toner cartridge once. Still running on the initial color cartridges. Laser is definitely better for occasional printers like me. They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
 --Benjamin Franklin
	Color laser printers are great for photos,who ever told you they weren't didn't have the right laser printer. I think,therefore i am a hamster.
	Good to hear that - our office color laser did terrible photos, but that was fifteen years ago. I'll consider one next time. Meanwhile, we have a Brother HL-L5200DW duplexing monochrome laser that cost $150 (Staples) and is still on its 3000-page starter cartridge. (It's our second such printer - we wore out a drum after 25,000 or so pages; it was cheaper to replace the whole printer than buy a new drum.) On those occasions when we want color, we have a $100 (Staples, again) HP OfficeJet Pro 8100 that is quite economical on ink and doesn't misbehave if it sits for several weeks without printing. It does excellent color photos on the appropriate paper.
 We've got a $60 all-in-one, primarily for (rare) fax calls, which I would not recommend to anyone. It drinks ink. It can take several minutes to self-test, usually at inconvenient times. That being said, it does a tolerable scan, and is convenient for multi-page documents.
  Help with Adapter?? SuggestionBy juliocasio in forum Newbie / General discussionsReplies: 1Last Post: 6th Mar 2018, 08:10
  Suggestion script to This VideoBy Caiosouza in forum RestorationReplies: 3Last Post: 14th Oct 2017, 10:23
  Browser suggestion?By kyrcy in forum ComputerReplies: 5Last Post: 14th Aug 2017, 11:03
  Need Non-subscription DVR suggestionBy AnchorMan in forum DVD & Blu-ray RecordersReplies: 11Last Post: 14th Dec 2014, 19:17
  hi plz suggestion for a freeware that will do thatBy videohelplover in forum Newbie / General discussionsReplies: 14Last Post: 26th Jul 2014, 22:01
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
			 luckily
  luckily
