Hi I successfully followed the Montblanc.dvd unlock to let my LG BP250 play region 1 discs. (Im in UK btw). They play fine, but im getting no sound at all from anything region 1, but fine in region 2. Any ideas ?
It was region 2 but I'd assumed using the Montblanc that it's now region free. I'm not too up on the details really, I set it to 0 which per the details I read should be region 0 if I'm right
did you try pressing the audio button on your remote ??
might also try doing a factory reset on the player (shouldn't affect the region free settings)
Sony BDPS6700 4K Upscaling Blu-Ray Disc Player/Make Multi Region Player
By swu1 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 7th Nov 2017, 15:05 -
Region on disc - drivers doing this from windows setting or editor/burner?
By larioso in forum Authoring (Blu-ray)Replies: 10Last Post: 22nd Mar 2017, 10:50 -
Should a Region 2 DVD played on a multi-region Blu-Ray player look normal?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 4Last Post: 11th Mar 2017, 09:46 -
Why does CSS protection cause problems burning to disc?
By katieburchett in forum Authoring (DVD)Replies: 7Last Post: 22nd Oct 2015, 06:51 -
Ripping pal region 2 to region 1 problems
By EricDraven in forum DVD RippingReplies: 16Last Post: 1st Jul 2015, 13:36
