I've been using Paul Glagla's DVDate to create .srt files for all my camcorder DV-AVI files in order to display the time/date count during playback.
I now have some .m2t (HDV) files from a different camcorder which I also want to create .srt files for. The .m2t files do have time / date when played back on the camera, so I know it's there, but unfortunately DVDate doesn't work on .m2t files, and I've been unable to find an alternative that can do the same for .m2t files (there is an old thread on this forum about this, but nobody seems to have found a way).
Then I had the idea that I could:
1. Convert the .m2t files to regular DV-AVI files (and hopefully the time/date code will then be present in the result DV-AVI conversion).
2. Use DVDate to create .srt files for the DV-AVI conversions.
3. Use the created .srt files together with the original .m2t files.
So basically I need to know which freeware software that can do this in a easy way, preferably with an easy to understand graphical interface, without command lines etc (unless there is a step by step guide telling me exactly how to do it). Any ideas?
You want just a single date/time SRT for the entire movie, derived from M2T metadata? Or are there multiple segments in one long video with different time/dates?
DVavi is only 720x480 and HDV is 1440x1080 or 1280x720. they aren't interchangable.
Time & Date Subtitle File Generator (.srt) - Testers Required
By time2innov8 in forum SubtitleReplies: 108Last Post: 5th Feb 2024, 18:31 -
Embedding Date/Time Stamp to AVI - Quality Loss?
By Genius in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 24th Feb 2019, 22:35 -
Inlay Date and Time Code to AVI - Quality Loss?
By Genius in forum Capturing and VCRReplies: 1Last Post: 24th Feb 2019, 12:53 -
How to create a fresh date / time stamp for a DV AVI file?
By guy24s in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 8th Feb 2019, 22:10 -
Convert a long avi video into a short time lapse avi
By Grampold in forum Newbie / General discussionsReplies: 3Last Post: 21st May 2017, 18:17
