I often download dual audio files, mainly anime, where the default audio language is set to english, and the subtitles are often set to signs/songs.
I used to manually select japanese audio/english subtitles when playing these files on my tv, but that has become such a hassle. So i found MKVToolnix, which works fine, and i can change the default audio/subtitles. But i have to change every file separately, since if i select all the files at once, it just creates one big video file instead of seperate videos (or i'm doing it wrong).
I've been looking up guides to do this, but almost every guide has these lines of code, which i really dont understand at all. Isnt there some easy way or program, to change the default audio/subtitles for a whole batch of videos?
jmkvpropedit (3rd party GUI for mkvtoolnix's mkvpropedit)
Sounds like you are wasting time remuxing instead of using the Header Editor which can alter flags in seconds. But it doesn't have a batch mode so you are better off using jmkvpropedit anyways. (Unless you need to copy your files to USB or something, then you might as well remux.)Last edited by sneaker; 13th Mar 2019 at 12:26.
I was in the same position as the topic creator. I had no problem changing the tracks with MKVToolNix, but I had over 100 files and it was killing my hand after doing the first 20 one by one. I tried selecting the rest of the files at once, but I still had to change the tracks for each one, and afterward it saved everything onto the first track, making one big file. I wish I would have looked this up in the first place though, because jmkvpropedit works. It even saves the changes in each file, rather than creating a new file for each video like MKVToolNix was doing. The only thing it didn't do was move the the new default track to the first slot. It just keeps it in the second slot and the original default remains in the first slot. However, this doesn't seem to matter, as all of the files I checked were still playing the new default automatically. So this will save you a lot of trouble.
Need Help Batch Remove Audio,Remove Subtitle,Change Default Audio and Sub
By Inoyama in forum Newbie / General discussionsReplies: 9Last Post: 9th Jan 2018, 16:20 -
Batch Mkvmerge change default audio, subitle + delete audio
By alloar in forum Newbie / General discussionsReplies: 2Last Post: 8th Jan 2018, 16:38 -
Setting Movie Only Bd Audio and PGS Subtitles to Default ON when not Reenco
By ScorpionStingz in forum SubtitleReplies: 0Last Post: 7th Nov 2015, 21:20 -
How to edit MKV data without remuxing (change default audio, rename lang)
By spycam in forum Newbie / General discussionsReplies: 10Last Post: 28th Jul 2015, 05:54 -
Easy tool to change audio fps
By davidbowie in forum AudioReplies: 20Last Post: 17th Jul 2014, 05:23
