Nothing to do with video I suppose, well, maybe if you downloading covers.
The last few days, using Internet Explorer or AOL, when I right-click and Save As a .jpg file, it saves as .jpg, but will not open in any viewer. If I change extension to .art, I can open it in Internet explorer, then re-save as a bitmap, then use PSP7 to convert it to a .jpg. Takes me a long time to down a cover and print it this way. Why has this started to happen all of a sudden. Have I clicked a setting somewhere without realising?
Incidentally, I am using XP!
:o
I had this happen to me to, it's something in the file assosiations.
Lucky it happened 2 days before I got my copy of XP and upgraded
Dont know whether this is applicable to WinXP but have you tried:
Under any folder go to
View(up the top) >>> Folder Options >>> File Types Tab
Then browse down till you find the JPEG and JPG file types and delete them. After that go to a .jpg(or .jpeg) file on your computer then when you click it should say choose a program to open the file with select Internet Explorer (or whatever program you want to use) and everything should be alright -
Sorry for the delay pacmania, but I'm usually innebriated. However, thnx for help but me just found out it an AOL thing. If me browse with Internet Exlorer then no probs
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 09:32 -
A hardware prob, but what?
By ahhaa in forum ComputerReplies: 3Last Post: 22nd Sep 2009, 21:00 -
Wireless prob?
By Immortal25 in forum ComputerReplies: 4Last Post: 3rd Jun 2009, 07:55 -
gc prob
By Mr anderson in forum ComputerReplies: 6Last Post: 10th Sep 2007, 05:33 -
MPEG DV prob
By mainegate in forum ffmpegX general discussionReplies: 0Last Post: 24th Aug 2007, 17:01
