Page 2 of 3
FirstFirst 1 2 3 LastLast
Results 31 to 60 of 86
  1. Member stax76's Avatar
    Nov 2009
    On thin ice
    mpv.net creates mpv.conf with mpv.net defaults if mpv.conf does not exist but if mpv.conf exists mpv.net does not modify mpv.conf!
    The same is true for input.conf.
    Feb 2015
    Spain
    In what folder does it create them?
    Feb 2015
    Spain
    Thank you. Where is this? <startup>\portable_config\mpv.conf
  4. Member stax76's Avatar
    Nov 2009
    On thin ice
    <startup> means the same directory where the executable has started, where the exe file is located.
    Feb 2015
    Spain
    Why do I have the buttons unconfigured after I have deleted the program?
    Feb 2015
    Spain
    After having deleted mpv-net the buttons of my original mpv are not properly configured. That's what I do not understand.
  7. Member stax76's Avatar
    Nov 2009
    On thin ice
    I can only guess what you miss, you might want to delete:
    C:\Users\%username%\AppData\Roaming\mpv
    and
    Feb 2015
    Spain
    Fixed up. Thank you. I just had to delete the new files that had been created here: C:\Users\%username%\AppData\Roaming\mpv
  9. Member stax76's Avatar
    Nov 2009
    On thin ice
    Next release takes into account that conf files can be located in the startup directory.
    if conf files exist in the startup directory mpv.net will use the startup directory as config directory instead of creating default conf files in appdata
  10. Member stax76's Avatar
    Nov 2009
    On thin ice
    Changelog
    3.5 (2019-05-09)
    • when the main windows gets activated and the clipboard content starts with http
      mpv.net will ask to play the URL, previously this was restricted to YouTube URLs
    • Python script errors show line and column whenever it is supported by IronPython
    • if conf files exist in the startup directory mpv.net will use the startup
    • renamed commands are handled now by migration code instead of being broken
  11. Member stax76's Avatar
    Nov 2009
    On thin ice
    Changelog
    3.6
    • playing files from rar archives caused an exception
    • there was a bug that caused underscores beeing removed from input like MBTN_LEFT_DBL
    • the search clear button in the input editor had a render issue in dark mode
    • new search feature added to search and play media files, requires
      Everything to be installed. Default Binding, Screenshot
  12. Member stax76's Avatar
    Nov 2009
    On thin ice
    • new icon design
    • the radio buttons in the config editor have now a Windows 10 like design,
      they are larger and use the Windows theme color
    https://github.com/stax76/mpv.net/releases
    https://postimg.cc/XZhVsVqc
  13. Member stax76's Avatar
    Nov 2009
    On thin ice
    • on the start screen the mpv.NET icon is shown instead of the mpv icon,
      feedback and contributions regarding the icon are welcome! The paint.net
      pdn and png source is located here
    • everytime only one file is opened the complete folder is loaded in the playlist
    • the info command (i key) shows the audio format
    • new options osd-font-size, sub-font, sub-font-size
    • new color options with dedicated GUI support: sub-color, sub-border-color, sub-back-color
    • the config editor no longer shows the command line switches
    • the github start page was greatly improved
    • the setup.ps1 PowerShell script was greatly improved in regard of error handling and readability
    • a manual to mpv.net was created
  14. Member stax76's Avatar
    Nov 2009
    On thin ice
    • drag & drop support for subtitles was added
    • libmpv was updated
    • command line support for stdin and URLs was added
    • there was a crash happening when the player is
      minimized in the taskbar
  15. Member stax76's Avatar
    Nov 2009
    On thin ice
    4.2 Letting Go
    • the help and layout in the config editor was improved
    • clipboard monitoring for URLs can be disabled in the settings
    • the context menu has a new feature: Open > Add files to playlist,
      it appends files to the playlist (Default binding)
    • a setting was added to force using a single mpv.net process instance
  16. Member stax76's Avatar
    Nov 2009
    On thin ice
    Since the last release there was more feedback than ever before (much on the issue tracker and people who starred the project). I would like to thank everybody for it. :thanks:
    4.4
    • clipboard-monitoring was replaced by url-whitelist:
      Keyword whitelist to monitor the clipboard for URLs to play.
      Default: tube vimeo ard zdf
    • some settings like colors didn't work because enclosing quotes were missing
    • when single process queue is used the folder is no longer loaded
    • the playlist is never cleared whenever the control key is down but
      files and URLs are appended instead
    • powershell script hosting bugs were fixed and a new powershell example script
      was added to the scripting wiki page
    • the menu entry for the command palette was renamed to 'Show All Commands' and
      the default key binding was changed to F1 which is also the default in VS Code
    • the default key binding of the Everything media search was changed to F3
    • support for the mpv property 'border' was added to the config editor
      to show/hide the window decoration (titlebar, border). A toggle menu item and
      key binding (b) was added as well (Default Binding)
  17. Member stax76's Avatar
    Nov 2009
    On thin ice
    • opening a URL manually no longer uses a input box but uses the clipboard directly
    • the manifest was missing the company attribute which caused
      mpv.net not appearing in the 'Open with' menu of the Windows File Explorer,
      thanks to 44vince44 for pointing this out!!!
    • new Python and C# script examples were added to the wiki and the scripting and
      add-on documentation was improved
    • invalid command line arguments were ignored, now an error message is shown
    • a description on how to start mpv.net from Google Chrome was added to the
      manual, it's useful to play videos from sites like YouTube, find the
      description here
    • new config setting remember-height added to remember the window height,
      otherwise the video's native resolution is used
    • support for protocols other then http added
  18. Member stax76's Avatar
    Nov 2009
    On thin ice
    • remember-height was replaced with start-size, when start-size is set
      to video the main video starts directly with the native video size,
      before it was starting with the autofit size first and was only
      afterwards resized to the native video size
    • on exit the window location can be saved with remember-position
    • in the learn window of the input editor underscores were stripped
      because they have a special meaning in WPF labels
    • fix for keys/input not working for MBTN_LEFT_DBL, MBTN_BACK, MBTN_FORWARD
    • in the learn window of the input editor support was added for
      mouse left, mouse left double, mouse mid, mouse forward, mouse back
    • libmpv was updated to shinchiro 2019-07-07
    • when border is none it wasn't possible to minimize the window from
      the task bar because this is the WinForms default behavier. This
      was fixed by calling Spy++ to the rescue and adding WS_MINIMIZEBOX
      in CreateParams
  19. Member stax76's Avatar
    Nov 2009
    On thin ice
    • on Win 7 the theme color was hardcoded to DarkSlateGrey because
      WPF was returning a bad color on Win 7, this was fixed by reading
      the theme color from the Registry on Win 7. If the theme color
      is identical to the background color it's corrected
    • dark-color setting was added to overwrite the OS theme color used in dark mode,
      find the setting on the General tab
    • light-color setting was added to overwrite the OS theme color used in non dark mode,
    • various changes regarding input handling, multi media keys and
      mouse forward/backward were successfully tested
    • it's now possible to use a custom folder as config folder, a TaskDialog shows five options:
      1. appdata mpv.net, 2. appdata mpv (shared with mpv), 3. portable_config, 4. startup, 5. custom
    • slightly increased startup performance, start-threshold setting added.
      Threshold in milliseconds to wait for libmpv returning the video resolution
      before the window is shown, otherwise default dimensions are used as defined
      by autofit and start-size. Default: 1500
    • autofit-smaller setting added. Minimum window height in percent. Default: 40%
    • autofit-larger setting added. Maximum window height in percent. Default: 75%
  20. Member stax76's Avatar
    Nov 2009
    On thin ice
    • changed icon design
    • libmpv was updated to shinchiro 2019-07-14
    • new or improved config editor settings: screenshot-directory,
      screenshot-format, screenshot-tag-colorspace, screenshot-high-bit-depth,
      screenshot-jpeg-source-chroma, screenshot-template, screenshot-jpeg-quality,
      screenshot-png-compression, screenshot-png-filter
    • mpv.conf preview feature added to config editor, it previews the mpv.conf content
    • in the entire project the term addon was replaced with the term extension,
      unfortunately this will break user extensions. The reason for this drastic
      change is that there exist too many different terms, addons, addins,
      extensions, modules, packages etc.. mpv.net follows Google Chrome as the worlds
      most popular extendable app, Chrome uses the term Extension.
    • a thread synchronization bug was fixed, the shutdown thread was aborted
      if it was running more than 3 seconds, this caused the rating extension
      to fail if it was waiting for a drive to wake up
    • a new JavaScript was included to show the playlist with a smaller font size,
      the script is located at startup/scripts
    • terminal support added using mpvnet.com !
    • script engine performance and error handling was improved
    • the scripting wiki page was improved
    • the C# scripting host extension was converted from VB to C# because it's not
      only used for hosting but I also use it now to code and debug script code
    • there was a copy paste bug in the file association feature resulting in keys
      from mpv being overwritten instead of using mpv.net keys. Thanks to floppyD!
    • there was a exception fixed that happened opening rar files
    • instead of using the OS theme color there are now default colors
      for dark-color and light-color
  21. Member stax76's Avatar
    Nov 2009
    On thin ice
    • 'Tools > Execute mpv command' was replaced with mpv-repl
    • many wiki pages were improved
    • the logo/icon had a very small cosmetic change
    • the help in the context menu was improved,
      for quick access consider the command palette (F1 key)
    • config options specific to mpv.net are now available from the command line
    • the input editor no longer has known limitations, 'alt gr' and ctrl+alt are working now
    • the help in the input editor was simplified and the filter logic was improved
    • fixed issue in file associations causing mpv.net not to appear in OS default apps
    • 'Tools > Manage File Associations' was replaced by 'Tools > OS Setup',
      it has now a feature to add and remove mpv.net to and from the Path
      environment variable and the OS default apps settings can be opened (Win 10 only)
    • startup folder and config folder being identical was causing a critical issue
      as mpv.net was loading extensions twice and scripts four times, now identical
      folders are no longer permitted
    • error messages are shown when unknown scripts and extensions are found in the startup folder
      because user scripts and extensions are supposed to be located in the config folder instead
    • changing from maximized to fullscreen did not work
    • the search field in the config editor was not always remembered
    • new setting remember-volume added, saves volume and mute on exit
      and restores it on start.
    • it's now enforced that mpv properties on the command line and in
      the mpv.conf config file are lowercase, if not a error is shown
    • gpu-api vulkan was not working if media files were opened via
      command line (that included Explorer)
    • new setting minimum-aspect-ratio added, minimum aspect ratio for the window,
      this was previously hard coded to 1.3
    • new setting auto-load-folder added, for single files automatically load
      the entire directory into the playlist, previously this was forced,
      now it can be disabled
    • new setting themed-menu added, follow theme color in context menu,
      default: no. UI related settings have now a separate UI tab in the config editor
  22. Member stax76's Avatar
    Nov 2009
    On thin ice
    I've uploaded a new release with small improvements.
    5.2
    • bug fix for single-instance not working with unicode filenames
    • bug fix for logo not shown on start
    • osd-visibility.js script was removed because the OSC uses too much memory
    • youtube-dl was updated
    • libmpv was updated to shinchiro 2019-08-04
    • in case mpv.net was started from a terminal it sets now the mpv property input-terminal to yes,
      this means mpv.net will now receive and handle input keys from the terminal
    • certain command line properties didn't work (input-terminal, terminal, input-file,
      config, config-dir, input-conf, load-scripts, script, scripts, player-operation-mode)
    • the about dialog shows now the mpv version and build date
    • the dialog that asks for a config folder has now a cancel option
  23. I'm new here. I've been using Potplayer but playing Youtube videos was very slow. I'm trying Mpv.net and it seems faster. But Youtube are playing on highest resolution and my unlimited data plan is capped at 720p for videos. How do I change the resolution? Thx.
    Update: I just found the solution. Add "ytdl-format=bestvideo[height<=?720]+bestaudio/best" line to mpv.conf
    Solved
  24. Member stax76's Avatar
    Nov 2009
    On thin ice
    Hi everybody,
    I'll try not to code for a time so this might be the last release this summer.
    I have to admit that I want to spend less time coding or even quit coding altogether but it's a long term goal and I might change my mind.
    Have a good time.
    5.3
    • added new feature: Open > Open DVD/Blu-ray Drive/Folder...
    • the default of remember-volume has been set to yes
    • scale, cscale, dscale defaults have been set to spline36,
      profile=gpu-hq is not used in the defaults because it starts very slow
    • new menu items have been added to navigate to the first and
      last playlist position, key bindings: Home, End
    • new config setting recent-count added, amount of menu items
      shown under 'Open > Recent'
    • in the config dialog the description for keep-open was corrected
      because unlike mpv, mpv.net will never terminate automatically
    • there was a rare occasion where the mpv.net logo wasn't shown
    • fix excessive memory usage using osd-scale-by-window = no
    • mpv setting osd-scale-by-window added to config dialog
  25. Member stax76's Avatar
    Nov 2009
    On thin ice
    • added taskbar-progress implementation
    • added new setting to start with maximized window
    • long file paths work now even if not enabled by the OS
    • fixed history being written even when history file wasn't created prior
    • libmpv updated to shinchiro 2019-08-31
  26. Member stax76's Avatar
    Nov 2009
    On thin ice
    - new: the [scripting wiki page](https://github.com/stax76/mpv.net/wiki/Scripting#powershell) was improved
    - new: Toggle Shuffle has been added to the menu defaults
    - new: for URLs the media title is shown in the title bar and in the info command
           instead of displaying the URL, mpv.conf defaults were changed to use
           [protocol.https] osd-playing-msg = '${media-title}'
    - fix: on the very first start volume was set to 0 and mute was set to yes
    - fix: there was a sound when closed from taskbar
    - fix: the log feature was not working
    - fix: clipboard monitoring removed because it was causing to many issues
    - fix: restore resulted in collapsed window when maximized = yes was used
    - update: libmpv shinchiro 2019-10-06
    - update: youtube-dl 2019-10-01
  27. Member stax76's Avatar
    Nov 2009
    On thin ice
    I've just uploaded a new release and hope that it's actually stable.
  28. Member stax76's Avatar
    Nov 2009
    On thin ice
    Hey everybody,
    I've uploaded a maintenance release, there is now an update check and routine.
    The release is all about PowerShell because the update routine is PowerShell based and I've also migrated the release script from C# to PowerShell. It's possible to install mpv.net with PowerShell but I don't maintain this yet so there is a delay, I'll investigate if I can take over the maintenance for the Chocolatey package.
    Let me know what you think about the default theme.
    5.4.4.0
    • new: forecolors in the dark theme are slightly darker now
    • new: readme/website and manual were improved
    • new: source code includes now the release script to build the archives and setup files
    • new: the history feature now uses the full path
    • new: install via Scoop and Chocolatey added to readme/website (Restia666Ashdoll)
    • new: update check, it must be enabled first in the conf editor under General
    • new: update feature, requires PowerShell 5 and curl,
      an up to date Windows 10 system has both included.
      Main menu (input.conf) must be reset or updated manually (defaults)
    • update: libmpv shinchiro 2019-11-10
    • fix: often the OSC was shown when fullscreen was entered
      or on app startup, this is now suppressed
    • fix: the file association routine uses no longer 'Play with mpv.net' for the
      default open verb caption because it doesn't support multi selection,
      it shows now only Open, the manual explains how to get multi selection
      in File Explorer, read about it here.
    • fix: x86 builds had an older version included because
      of a misconfiguration in the solution file
    Link to the project can be found in my signature.
