I want to reposition subtitles on many files and it seems tedious. Is there a way to reposition all subtitles in mutiple files?
Results 1 to 13 of 13
What is the source subtitle format and container? What is the target subtitle format, container and player?
Do all your .ass files use the same style(s)? Try SubtitleEdit: "Tools"->"Batch Convert". Add all .ass files, choose "Advanced Sub Station Alpha" and change the "Style".
The "Style" button only appears after you have selected the "Advanced Sub Station Alpha" format.
I dont get that choise though, it says Advanced Sub Station Alpha next to the subtitle when i add one to the list. I don't choose it.
[Attachment 48337 - Click to enlarge]
If that option isn't there maybe your SubtitleEdit version is outdated. -
In the Style menu you can set margins or directly edit the raw ASS header. You haven't said what exact type of positioning you need.
Don't make me guess so much ...
So it's 1920x1080 video and you want 50 pixels bottom margin with horizontal center position? In the style select "Bottom/center" alignment and set "Margin vertical" to 50.
This dummy can't sync subs with Subtitle Edit or Subtitle Workshop :-(
By inspector_plodder in forum SubtitleReplies: 6Last Post: 24th Aug 2018, 18:33 -
Pixelated and laggy video on Subtitle Workshop and Subtitle Edit
By Valerc in forum SubtitleReplies: 5Last Post: 15th Jul 2018, 11:37 -
By Valerc in forum Newbie / General discussionsReplies: 2Last Post: 13th Jun 2018, 14:15 -
Bulk delete files in multiple .zip files
By Noahtuck in forum ComputerReplies: 17Last Post: 25th Oct 2014, 01:26 -
Bulk add Credits / Intro video in each video files in a directory
By farhanisfarhan in forum EditingReplies: 7Last Post: 25th Jul 2014, 09:37
