Is it possible to first erase the contents within a BDMV folder that is resident on an HDD, then copy and paste the BDMV folder contents from an unlocked BDMV folder on a Blu-ray Disc to the BDMV folder on the HDD and then burn to disc the BDMV folder thats on the HDD to play on a blu-ray player? if not why?
Maczones
the question is vague. all that's required to burn and play a bluray is the bdmv folder. as long as it's not copy protected. if it is then no just switching folders will not work the copy protection is smarter than you.
Thanks for your response, now less vague:
1. The BDMV folder in the disc is not copy protected
2. I've tried copying that BDMV folder straight from the disc to the HDD and the BDMV folder changes properties and is unblessed... Result,,, does not work
3. Workaround is to have a BDMV folder already resident on the HDD, strip the contents within that folder and then copy all the contents within the BDMV folder on the disc to the BDMV folder on the HDD
4. I only need to know if I perform steps 1 and 3, then burn the BDMV, will it properly read and played on the Bluray player? .... Yes or No
I am very much aware of what AACS is and how that works. -
Hi! I have another question about it. Can I remove the movie in the stream folder and put a mkv file? I mean sometimes I get bdmv folders but the movie doesn't have spanish language or subtitles etc so I remux the original file with the audio I need.
Is it posible make a Bd with this file removing the original? -
Interesting question but not sure if this works as I have never tried it and see no reason why. Subtitles are best added by using tsMuxer to replace an existing PGS file and then taking the new files created and replacing them into the original BDMV folder.
Hope this helps. Btw, my previous question does work if you follow what I stated.
No BDMV exists in AVCHD folder
By CM120884 in forum Video ConversionReplies: 1Last Post: 16th May 2018, 18:32 -
Create MKV from a BDMV folder?
By elcoyoteloco in forum Blu-ray RippingReplies: 17Last Post: 4th Feb 2018, 05:06 -
Convert BDMV folder? to MKV!
By tOkyO1 in forum Blu-ray RippingReplies: 3Last Post: 3rd Feb 2018, 23:59 -
Having trouble playing BDMV STREAM folder on Sony TV
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 11th Jul 2016, 10:21 -
Convert BDMV folder with eac3to piped to ffmpeg
By z-machine95 in forum AudioReplies: 3Last Post: 11th Aug 2015, 14:12
