  1. Hi Gang
    I'm using Wondershare Video Converter Ultimate 10.4.2 and would like to know if there's a way to extract the audio portion only from a video in order to try to correct some problems? But as I think about it Video Converter is not a full video editor so there is probably no way for me to bring it back in (sync it up)?
    ThanK You
    Mar 2011
    Nova Scotia, Canada
    Don't use wondershare (frankly it doesn;'t have a great reputation) but you can open a video file in AUdacity and it'll just load the audio. Then you can do whatever.
    You may be able to import an external audio track in Wondershare, I don't know, if not I'd look for something else.
  3. What type of video file is it (AVI or MKV or MP4 etc)?
  4. Thank You Hoser and hello_
    You're correct: honestly I need to fire up FC on my Mac, use Audacity on my PC or install an older version of Magix for my PC for some 'light' video editing.
    Best Regards - Mike
