  1. Hello! I have create a SUP file and i wanna burn it to my video files with Vidcoder but i cant! I can only add SRT files! I try to converte it to .idx file and added with mkvmerge added fine but i dont see nothing inside my video files! Any help ?
    Thanks!
  2. Make sure you haven't ticked "forced only" if the lines you want aren't marked as such.
    The sup is from Blu-Ray and 1920x1080 resolution? Is your video cropped/resized to something lower than 1920x1080?
  3. Originally Posted by sneaker View Post
    I have create a SUP file with SubtitleCreator! Then i wanna add this SUP file include my video i try it but not working! I try with mkvmerge!
  4. 1. Why do you create SUP instead of SRT?
    2. What is "not working"? Any error message? From mkvmerge? From VidCoder?
    Show MediaInfo ("View"->"Text") of your subtitle and mkv files. Attach subtitle file here. Show VidCoder settings and log.
  5. Originally Posted by sneaker View Post
    Because i wanna create subs with color and put it in the center of the video file! Can i do it this to a srt file ?
  6. No, but you can do it using VobSubs, ASS and SSA subs. Can you convert the SUP file to IDX/SUB (Vobsubs)?
    Subs in the middle of the video?
  7. VidCoder supports some SRT tags like color and alignment. In SubtitleEdit right-click one or multiple lines and set "Color" or "Alignment" and save to SRT.
    Result would look like this:
    00:00:31,532 --> 00:00:34,243
    {\an5}<font color="#ff0000">(FLÜSTERN AUF ELBISCH)</font>
    2
    00:00:34,660 --> 00:00:37,704
    {\an5}<font color="#ff0000">Die Welt ist im Wandel.</font>
    3
    00:00:37,913 --> 00:00:40,916
    {\an5}<font color="#ff0000">Ich spüre es im Wasser.</font>
    {\an5} is alignment in center and ff0000 is red color.
    (Normally I wouldn't recommend this but if you are hardcoding anyways there isn't much harm using this bastard format. Otherwise I would recommend ASS like manono but specifically for VidCoder SRT has the advantage of not needing to mux video and subtitle together first.)
