I’ve finally managed to get DVDx working with CCE2.64, but only if I use 10Mb on the save you DVD drive. If I use more, then and after a while it stops responding.
This seams to happen when the progress bar appears, the one that shows when reading the DVD. If I use 10Mb then the bar doesn’t come up.
At the end of the encoding it also tells me that the Video is longer than the audio or some kind of msg.
Any help or advise for the 1st problem since the second isn’t really a problem
