Replace it with the correct version, or move it to subfolder if you don't need it
x64 plugins
http://avisynth.nl/index.php/AviSynth%2B_x64_plugins
Results 31 to 35 of 35
The version of deblock_qed.avs I have doesn't use binarize(). Try this one:
http://avisynth.nl/index.php/Deblock_QED
It's newer than the version I had but I just checked it and it works with AviSynth+ 64 bit. -
Never ending chain of errors
As per this thread https://forum.videohelp.com/threads/335181-Keep-getting-libfftw3f-3-dll-could-not-be-loaded-error
I have put libfftw3f-3-dll in in C:\Windows\SysWOW64
Still getting the same error -
SysWOW64 is for x86 , System32 is for x64
That script will run perfectly fine in x86 too (even on a x64 host OS) . You need to keep things separate. Many people have concurrent x86 + x64 avisynth installs
But x64 avisynth, encoder, full processing chain has benefits in terms of memory, speed
Can you please suggest some good software which can edit without encoding?
By seymoria in forum EditingReplies: 20Last Post: 3rd Feb 2018, 04:18 -
Please suggest a good microphone solution for Sony AX53 camcorder
By Srivas in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 4th Oct 2016, 11:05 -
I discarded 93% from my 1080/60p source, it doesn't look good. What to do?
By newpball in forum EditingReplies: 19Last Post: 6th Apr 2015, 10:58 -
Suggest a Good AVR with MKV Playback
By new93 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 2nd Aug 2014, 13:48 -
I'm looking for a good free movie editor, can you suggest ?
By carlyn101 in forum Newbie / General discussionsReplies: 4Last Post: 20th Jul 2014, 22:06
