Hi all,
I'm having the following problem I can't solve on my own and Google doesn't give anything.
I have an M2TS file with two audio tracks: an LPCM and an AC3. I'm looking to copy without re-encoding (need to make some slight edits) but the output file will only retain the AC3 track no matter what I do in Audio > Select Track. The main window indicates 2 tracks selected but only outputs the AC3. Here are the source file details.
How do I output both tracks please?
Video
Codec 4CC: H264
Image Size: 1920 x 1080
Aspect Ratio: 1:1 (1:1)
Frame Rate: 23.976 fps
Total Duration: 01:37:09.281
Extra Video Properties
ExtraDataSize: 00
Audio
Codec: LPCM
Channels: Stereo
Bitrate: 192000 Bps / 1536 kbps
Frequency: 48000 Hz
Total Duration: 01:37:08.581
Audio
Codec: AC3
Channels: Mono
Bitrate: 24000 Bps / 192 kbps
Frequency: 48000 Hz
Total Duration: 01:37:08.425
One thing to try is to repackage your m2ts into an MKV using mkvtoolnix,
then use this new file as your source
AviDemux doesn't support AAC-LC in ADTS?
By yetanotherlogin in forum AudioReplies: 0Last Post: 22nd Jan 2019, 04:06 -
How to demux Audio tracks of multiple .avis in Avidemux automatically?
By Gwar in forum AudioReplies: 6Last Post: 21st Jun 2016, 11:49 -
Avidemux: filter doesn't shift audio
By MovingParts in forum EditingReplies: 13Last Post: 18th Sep 2015, 14:19 -
Convertxtodvd: 2 or More Audio Tracks doesn't work in my projects
By devilcoelhodog in forum Authoring (DVD)Replies: 1Last Post: 9th Nov 2014, 10:06 -
Avidemux error : Some tracks are used multiple times
By Hitesh12 in forum Newbie / General discussionsReplies: 4Last Post: 4th Nov 2014, 09:59
