I shot a video in 4K 30FPS and rendered it in Premiere at 4K 30FPS with synced audio and now added Toonit! effects in After Effects. I want to lower the frame rate to render a rotoscoped cartoon version from After Effects in a lower frame rate at 4K 15FPS. When I export from After Effects I chose to change the 30FPS to 15FPS and keeping the bitrate the same at 40MBPS and 4K and added to the media encoder queue.
I have never attempted this so I don't know if dropped frames will also drop audio since the end clip ends up a 1.5 seconds shorter.
Will this ruin the hardcoded audio by dropping half the frames? If so, is there something I could tune to successfully drop half the frames, keep 4K resolution and not end up with poor audio?
Results 1 to 1 of 1
How can I recreate the FCP7 "Ripple Dissolve" effect in Premiere Pro?
By Cyrax9 in forum EditingReplies: 0Last Post: 27th Feb 2019, 19:16 -
Reducing ghosting on 25FPS and 30FPS mixed footage in Vegas Pro 12
By guitarman320 in forum Video ConversionReplies: 6Last Post: 4th Jan 2017, 19:39 -
Premiere Pro CC 2014 - Multicam Applying effect to only one camera
By shorto in forum EditingReplies: 5Last Post: 12th May 2015, 15:37 -
DVR recorded movie will only capture at 15fps instead of 30fps
By SM26 in forum Capturing and VCRReplies: 5Last Post: 23rd Nov 2014, 11:40 -
New PC for video editing, C4D, After Effects, Premiere Pro.
By soulgolem in forum EditingReplies: 5Last Post: 28th Sep 2014, 16:28
