All of the tools seem to mention MKV, but not MPV files.
Results 1 to 18 of 18
General
Complete name : G:\Misc video\2nd Cup (June 12, 2008).mpv
Format : MPEG Video
Format version : Version 2
File size : 1 023 MiB
Duration : 17 min 52 s
Overall bit rate : 8 001 kb/s
Video
Format : MPEG Video
Format profile : Main@Main
Format settings : CustomMatrix / BVOP
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=15
Format settings, picture structure : Frame
Bit rate mode : Variable
Bit rate : 8 001 kb/s
Maximum bit rate : 9 800 kb/s
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 (30000/1001) FPS
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.772
Time code of first frame : 01:00:00:00
GOP, Open/Closed : Open
GOP, Open/Closed of first frame : Closed
Stream size : 1 023 MiB (100%) -
normally you'd mux them into an .mpg file. any reason you have to create an .avi ? it would be a non standard usage.
I was hoping to avoid further compression and am under the impression that AVI is "lossless".
I installed AVIDemux, tried loading he MPV and got the following message:
"Cannot find a demuxer for d:\.........xxxxxx.mpv",
"Could not open the file"Last edited by robertazimmerman; 5th Mar 2019 at 17:23.
You have an mpeg-2 MPV and you mentioned avi files earlier.
How does WMV fit into the picture?
If you want it as lossless mux it using mpeg PS muxer and save as .mpg -
"avi" is just the name of a container for video. not usually lossless, but can be made so with re-encoding. an mpv is usually combined with audio and muxed into vobs for use on dvds by an authoring program.
davexnet: I typed WMV in error; the file is in MPV format.
JVRaines: I used FFE with ffmpeg and it appears that I can convert the file to another format, but I'm not sure how to mux the audio file in concurrently. I'll keep trying. Failing that, I guess I can always use VirtualDub to mux in the audio. If I used ffmpeg to convert the MPV to another file format first, is there a best option output for minimal or no loss in quality?
BTW, thanks to everyone for your suggestions!!!Last edited by robertazimmerman; 5th Mar 2019 at 22:55.
LPCM wav is rarely supported in MPG (obvious exceptions:VOBs BD M2TS, etc). But Mpeg Video is also rarely supported in AVI (there are exceptions there also).
Maybe a better container would be MP4 or MKV? Either one should be able to be muxed into those.
Scott Warren -
if it's not copyright protected you could upload the video and audio and let us actually see what is the problem. and what is your end desire? how do you wish to view/share the completed video?
Just drag the video file and desired audio into MKVToolNix and make a MKV container. No compression or re-encoding. Quality in = quality out.. Simple to do in a few minutes.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
FFMBC how to remux with an external audio .wav file?
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 7th Aug 2018, 06:08 -
How can I mux an .avi and a 88.2kHz 24-bit .wav file without re-encoding?
By silentbob in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2017, 19:56 -
How do I Combine Video Files and Audio Files into One File?
By ChikiBiki in forum Newbie / General discussionsReplies: 3Last Post: 17th Aug 2016, 14:25 -
how to create a virtual file linked to the a real .avi video file ?
By marcorocchini in forum Newbie / General discussionsReplies: 13Last Post: 5th Dec 2015, 09:34 -
Easy tool for Windows to combine video and sound into a single file?
By yetanotherlogin in forum EditingReplies: 2Last Post: 15th Nov 2014, 11:31
