Page 2 of 2
FirstFirst 1 2
Results 31 to 32 of 32
  1. Originally Posted by zanzar View Post
    where do i write the line?
    A GUI should take care of it automatically. That's the reason for using a GUI .
    But those things are missing from the commandline in the log . Does staxrip allow you to add commands like megui ?
    If not, file a bug report so it can be fixed
    (actually --sar 40:33 in your log suggests it was NTSC 16:9 . Soin that example the missing things should probably be --fps 24000/1001 --input-res 720x480 --input-depth 10 --input-csp i420 )
  2. Originally Posted by zanzar View Post
    so is there any way to fix this?
    Using Staxrip you just leave it as is, I was pointing why that script is so elaborate.
    That script in your log file loads py moduls from anywhere in PC (Staxrip directory) so Python can see those and Vapoursynth DLL's as well.
