    Aug 2005
    Europe
    Can anyone recommend a utility (preferably freeware) to monitor HDD access? What I want is to know which application is currently accessing (mainly writing) the HDD/SSD and what file/folder is being used.
  2. Member valvehead's Avatar
    Mar 2006
    Resource Monitor is built into Windows.
    valvehead//
    Aug 2005
    Europe
    When I run Resource Monitor, I only get an empty window. Can anyone think why?
Name:	Resource Monitor.jpg
  4. Mod Neophyte redwudz's Avatar
    USA
    Works for me in W10, though I don't know how to use it.
Name:	Resource Monitor.JPG
    Aug 2005
    Europe
    Problem solved by enabling "Use visual styles on windows and buttons" under Advanced System Settings, Performance Options, Visual Effects.
    But I don't really like to use visual styles. How can I have Windows Classic Theme and be able to run Resource Monitor?
