  1. Hello,
    when frameserving dvd rips to tmpeg, it often sets the source to "interlace" but sometimes, it doesn't. Of course the encoding process takes nearly twice as long. Can I use a "no interlace" setting without losing quality when the result should be viewed on television only?
    Kind Regards,
    NiteFlame
  2. If the source is interlaced, then you either have to de-interlace or encode it as interlaced. For vcd you HAVE to de-interlace.
  3. also for SVCD? Thank You so far!
    Regards,
    NiteFlame
    Nov 2001
    Brazil
    SVCD accepts interlaced videos...
    Fredİ
