  1. Member gastrof's Avatar
    Sep 2004
    comfy chair
    Has anyone here heard of something called "Make MKV"?
    Someone on YouTube did a video about it.
    https://www.youtube.com/watch?v=nH18K-7s9_8
    It's said to allow ripping (any?) blu-ray disc. Has anyone here had any experience in using it, and if so, would you comment on what you think of it?
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    I use in for DVD's. I didn't know that it works with Blu-Ray discs, but then I wouldn't want a 50gb video file either.
    With DVD's, it simply takes the video, audio, and subtitle files and places them into a mkv container. The video and audio are not converted, thus there is no quality loss.
    The only downside, is the file sizes are larger than if you performed a conversion. For DVD material, this isn't a huge deal and you want to have files with the best quality possible. For Blu, file sizes can be huge.
    Google is your Friend
  3. Simply visit the tool site MakeMKV on videohelp and read its reviews, useless new thread.
  4. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    I have used this for all my DVD's and Blu ray discs. Then removed items within the MKV that I don't need and transferred the entire collection to my NAS. File size is not an issue for me but maintaining original video and audio quality is. Excellent program...
    Jul 2007
    Search MakeMKV on this site and there are hundreds of posts and dozens of regulars here that use and recommend it.
