Hi All,
I'm new here, I hope you don't mind helping me.
I'm not great with After Effects or Premiere Pro. I'll try and cut to the chase.
I have created a nested sequence of letters falling from the top of the screen to the bottom, an animation for a title sequence. Is there a way I can use this nested sequence in another video to save me creating the animation again from scratch?
Thank you.
Within the same project, just cut and paste the subsequence or subcomp. Drop it wherever you need it.
Both Premiere or After Effects allow you to import projects into other projects File/Import/ProjectName.prproj or Projectname.aep and of course you can share timelines between both programs.
But usually the simplest way is to render out the subsequence as a high resolution clip that you can import and use at will. If you have transparency, exporting as Quicktime/Animation is probably still the best option. -
Final Cut Pro and/or Adobe Premier Pro
By Filtered in forum EditingReplies: 2Last Post: 9th Oct 2017, 17:18 -
How do I tell ffmpeg to export a image sequence to a MP4 video libx 264. Bu
By oduodui in forum EditingReplies: 3Last Post: 23rd Jun 2017, 18:12 -
Exporting subtitles from SE to use on Premier Pro Version6 video
By Anna1 in forum SubtitleReplies: 0Last Post: 22nd Jan 2016, 01:13 -
adobe Premiere Pro CS4 help with sequence presets
By mc0810 in forum Newbie / General discussionsReplies: 2Last Post: 2nd Jun 2014, 13:54 -
How can I download Adobe Premier Pro CS6?
By JasonSabo in forum EditingReplies: 1Last Post: 23rd Apr 2014, 21:49
