Hey I just get a Video8 camcorder from the 80s and I only have Hi8 tapes, not standard 8mm. Is it OK to use them for standard Video8?
Why don't you try it and let us know, but most likely won't work - although it may ok if the tapes were recorded in a video8 machine, this do not have hi8 encoding
if you are referring to having only new hi8 tape to record on in a v8 cam the answer is maybe. v8 used metal-particle (mp) tape whereas hi8 could use mp or metal-evaporated (me) tape.
mp tape works in both v8 and hi8 cams. should be no problem.
Can I record Hi8 quality on video8 tapes?
By chinhang899 in forum Newbie / General discussionsReplies: 5Last Post: 27th Oct 2017, 04:00 -
Do these settings look good in AmaRecTV for capturing Video8 and Hi8 tapes?
By videon00b in forum Capturing and VCRReplies: 53Last Post: 11th Oct 2017, 08:18 -
Capturing Video8/Hi8
By pvrbulls in forum Capturing and VCRReplies: 13Last Post: 12th Feb 2017, 09:31 -
High-end HI8 deck / camcorder to capture PAL video8 tapes
By FLP437 in forum Capturing and VCRReplies: 2Last Post: 29th Mar 2016, 11:28 -
Camcorder breaking my Hi8 and Video8 tapes
By tradermarco in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 26th Dec 2015, 21:59
