(very sorry for my very bad english)
I have: 1.MKV, 2.MKV,...,~400.MKV
All MKV: 1 Video, 1 Audio, 0-3 Subs.
The typ (resolution, framerate and so on) of video-, audio- and sub-streams are absolut intentical in all MKVs.
I append the MKVs with MKVToolnix.
The video and audio was very good, no errors.
But with the subs there are this problems. Example:
25.MKV:
ID=2, pgs-subs, german forced
ID=3, pgs-subs, german full
ID=4, pgs-subs, english full
39.MKV:
ID=2, pgs-subs, english full
42.MKV:
ID=2, pgs-subs, german full
ID=3, pgs-subs, english full
The subs in the result of MKVToolnix are err, because the subs-IDs are not identical in all MKVs.
I want, that MKVToolnix sort the subs with her language and not with her ID.
To move in MKVToolnix the subs manually is too much work for me
Can anyone help me please?
I don't think there's an option for that.
The author isn't active on this forum. He takes feature requests on gitlab. (Of course he doesn't implement all requests.)
https://gitlab.com/mbunkus/mkvtoolnix/issues -
To be frank I'm surprised mkvtoolnix doesn't abort directly since the stream count differs.
No, according to what you wrote you want the subs to be matched by your manual naming of the streams not their language looking at '25.MKV' ID=2 and ID=3 both have the same language,... (if the language really was unique ffmpeg could be used to used to do what you want)I want, that MKVToolnix sort the subs with her language and not with her ID.
-> I hardly doubt Mosu (mkvtoolnix author) will implement support for something like that.
Depending on what you want to do with the mkvs, mkv segment linking might be a better solution than really appending the files,...
(I wrote a gui for mkv segment joining a while back https://github.com/Selur/MKVSegmentJoiner, no clue whether there is still a binary of it floating around the net,..)
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
I'm not sure players will be happy if you link mkvs with different stream counts/types.
It's worth a try, isn't it? Otherwise I don't really see a way aside from writing a (not so simple/short) program/script to do what he wants.
Converting multiple video files to MKV using MKVToolnix
By pcmacbob in forum Newbie / General discussionsReplies: 5Last Post: 7th Sep 2022, 14:24 -
Taking subs from mkv A and B to replace subs from mkv C in a different lang
By Boxgoblin in forum SubtitleReplies: 2Last Post: 26th Nov 2017, 13:00 -
Issing re-joining mkv files split using mkvtoolnix
By Odaik in forum Video ConversionReplies: 47Last Post: 31st Mar 2017, 16:25 -
Not able to demux from an MKV file using MKVExtractGUI (with mkvtoolnix)
By mrjayviper in forum Newbie / General discussionsReplies: 5Last Post: 30th Jun 2015, 22:15 -
MKV vs MP4 in regards to multiple audio streams and subs
By keesio in forum Video ConversionReplies: 6Last Post: 7th Apr 2014, 01:50
