The past few times I've tried to create a waveform using SE it has been really slow. It used to create the waveform in a matter of minutes, but lately it's been going at such a slow speed that it would take several hours. I should mention that I'm using a laptop, so I don't know if it's a memory or space issue, but I was using this same laptop before when it was working fine. Does anyone have any ideas what might be causing this?
Be sure you have latest VLC installed, go here: https://www.videolan.org/vlc/download-windows.html
If you're on a 64-bit OS which most ppl are, then press the arrow-down in the orange download button and choose the "Installer for 64-bit version".
Do use latest version of SubtitleEdit
3.4.6 is like four years old!
Alternately you can use FFmpeg for generating the waveform instead of VLC. In SE, go to Options -> Settings -> Waveform (download and check "use FFmpeg...")
You should also have at least a few GB free on your main drive (where your %temp% folder resides).Last edited by Nikse; 3rd Mar 2019 at 14:14. Reason: typo
Subtitle Edit - waveform problem
By AllaRosie in forum SubtitleReplies: 8Last Post: 12th May 2024, 06:21 -
Big problem :-( Translating subtitles on Subtitle Edit into Hebrew
By Asubtitler in forum SubtitleReplies: 4Last Post: 30th Dec 2018, 09:42 -
Updated Subtitle Edit today and have problem
By MourningStar in forum SubtitleReplies: 2Last Post: 1st Oct 2018, 23:18 -
problem with Subtitle Edit 3.4.11
By whitelighter27 in forum SubtitleReplies: 26Last Post: 1st Dec 2016, 14:55 -
Problem wih subtitle edit
By mitof1 in forum SubtitleReplies: 7Last Post: 19th Aug 2016, 03:11
