Hi,
I'm working on correction of many videos natively interlaced, but converted in progressive without deinterlacing. I think these videos was interlaced PAL format 720x576, then resized to 720x540. The results is inhevitable.
I'm trying to remove the artifacts of interlacing with VirtualDub. In the next reply, I'll attach an image of what I'm doing. If you have any suggestions, you are welcome!
Yes, resizing interlaced video without first deinterlacing is about the worst thing that can be done to a video.
A few of us did try to "un-do" the artifacts in a video that was damaged this way by using some AVISynth scripts we developed in this thread:
repair bad deinterlacing
This was a particularly bad re-size, although the artifacts are quite typical of what happens, where you end up with something that looks a little like the interlacing "teeth" which show up when interlaced video is played on a progressive display, but the "teeth" you get when video is borked this way are many "scan lines" (rows of pixels) high, rather than just one line/row, as would be the case with normal interlaced video.
The result of our efforts looked massively better than what the OP started with, but having said that, it would never, ever be mistaken for pristine footage.
Resize interlaced video without making it progressive
By xMike in forum EditingReplies: 5Last Post: 31st May 2018, 09:26 -
part progressive, part interlaced - correct avisynth coding question
By pooksahib in forum Video ConversionReplies: 14Last Post: 15th Dec 2016, 13:21 -
how do i use ffmpeg to see if a video is interlaced or progressive ??
By oduodui in forum EditingReplies: 3Last Post: 30th Jun 2015, 06:33 -
Determining if video is progressive or interlaced
By SameSelf in forum Video ConversionReplies: 10Last Post: 9th Mar 2015, 03:13 -
Interlaced scanning, progressive video?
By hello_hello in forum Video ConversionReplies: 23Last Post: 4th Nov 2014, 17:38
