For your interest, here is the MediaInfo information from one of the .mxf files we broadcast on our U.S. TV station.
Code:General Complete name : Title.mxf Format : MXF Commercial name : XDCAM HD 35 Format version : 1.3 Format profile : OP-1a Format settings : Closed / Complete File size : 180 MiB Duration : 39 s 706 ms Overall bit rate mode : Variable Overall bit rate : 38.0 Mb/s Encoded date : 2019-02-25 16:30:45.208 Writing application : Grass Valley K.K. EDIUS 8.2.0.312 Video ID : 2 Format : MPEG Video Commercial name : XDCAM HD 35 Format version : Version 2 Format profile : Main@High Format settings : CustomMatrix / BVOP Format settings, BVOP : Yes Format settings, Matrix : Custom Format settings, GOP : M=3, N=15 Format settings, wrapping mode : Frame Codec ID : 0D01030102046001-0401020201030300 Duration : 39 s 706 ms Bit rate mode : Variable Bit rate : 35.0 Mb/s Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate : 59.940 (60000/1001) FPS Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.634 Time code of first frame : 00:00:00;00 Time code source : Group of pictures header GOP, Open/Closed : Open GOP, Open/Closed of first frame : Closed Stream size : 166 MiB (92%) Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio #1 ID : 3 Format : PCM Format settings : Little Format settings, wrapping mode : Frame (AES) Codec ID : 0D01030102060300 Duration : 39 s 706 ms Bit rate mode : Constant Bit rate : 768 kb/s Channel(s) : 1 channel Sampling rate : 48.0 kHz Frame rate : 59.940 FPS (800.8 SPF) Bit depth : 16 bits Stream size : 3.64 MiB (2%) Locked : Yes Audio #2 ID : 4 Format : PCM Format settings : Little Format settings, wrapping mode : Frame (AES) Codec ID : 0D01030102060300 Duration : 39 s 706 ms Bit rate mode : Constant Bit rate : 768 kb/s Channel(s) : 1 channel Sampling rate : 48.0 kHz Frame rate : 59.940 FPS (800.8 SPF) Bit depth : 16 bits Stream size : 3.64 MiB (2%) Locked : Yes Other #1 ID : 1-Material Type : Time code Format : MXF TC Time code of first frame : 00:00:00;00 Time code settings : Material Package Time code, striped : Yes Other #2 ID : 1-Source Type : Time code Format : MXF TC Time code of first frame : 00:00:00;00 Time code settings : Source Package Time code, striped : Yes Other #3 Type : Time code Format : SMPTE TC Muxing mode : SDTI Time code of first frame : 00:00:00;00
				Results 1 to 16 of 16
	Here is an ffmpeg command I came up with to convert an mp4 file. The high bit rate is needed to keep the levels within spec. The scale filter is to keep the colors accurate.
 Code:ffmpeg -y -i output.mp4 -vcodec mpeg2video -pix_fmt yuv420p -s 1280x720 -r 59.94 -b:v 35M -vf scale=out_color_matrix=bt709,lutyuv=y='clip(val,16,235)' -acodec pcm_s16le -ar 48000 -ac 2 output.mxf
	Is ffmpeg handling the audio correctly with your command or just expanding the first channel to stereo while completely discarding the second one?
 https://trac.ffmpeg.org/wiki/AudioChannelManipulation#a2monostereo
	I would merge the two mono tracks using the "amerge" filter into a single stereo track like described in my link. I think you are doing "mono -> stereo" but should be doing "2x mono -> stereo".
	I looked at your link.
 Why wouldn't ffmpeg simply pass the one stereo pair without changing anything?
 Viz.:
 L -> L
 R -> R
 To do what you're suggesting would require two input files:
 Code:ffmpeg -i left.mp3 -i right.mp3 -filter_complex "[0:a][1:a]join=inputs=2:channel_layout=stereo[a]" -map "[a]" output.mp3
	Because like MediaInfo it doesn't see a single stereo track, it sees 2 mono tracks. By default ffmpeg only maps one audio track.
 https://trac.ffmpeg.org/wiki/Map#Default
 No.
 Code:ffmpeg -i "whatever.mxf" -map v -filter_complex "[0:a:0][0:a:1]amerge=inputs=2[a]" -map "[a]" "output.mp4"
	I think he's starting with a MP4 with stereo audio , not a MXF with two mono audio streams
	I thought the same as sneaker. Next time describe it with a few words what you want to do exactly, otherwise I won‘t give help anymore here. Especially from a guy who works for a tv station I can expect that.
 Just look at the title - it says nothing except one format.
	What concerns me is that the Y levels change if the video bit rate is reduced.
	If the bitrate is reduced, the quantizer changes. When the quantizer changes, it makes rougher guesses based on more constrained info - some of which includes individual Y, U, or V values. You should expect this when bitrate is reduced...they're called artifacts.
	You said, in post #2, "high bitrate is needed to keep levels within spec". What spec are you referring to? That spec should determine what you should be doing. Considering your source is 35Mbps, and IS in spec for XDCam, doesn't make sense to me to be doing ANY converting unless necessitated by a different spec.
  MXF file conversionBy louisedenham in forum Video ConversionReplies: 5Last Post: 17th Feb 2017, 11:03
  Audio Problem with MXF File ConversionBy Carl Enslin in forum AudioReplies: 8Last Post: 24th Dec 2014, 09:05
  Audio Problem with MXF File ConversionBy Carl Enslin in forum Video ConversionReplies: 2Last Post: 23rd Dec 2014, 14:03
  if I have a .mxf file, what is the best to load it on VirtualDubMODBy marcorocchini in forum Newbie / General discussionsReplies: 3Last Post: 11th May 2014, 11:06
  can I open .mxf file in virtualdub..By marcorocchini in forum Newbie / General discussionsReplies: 10Last Post: 23rd Apr 2014, 08:28
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
