Hi, my problem is that in new divx 5 format, with compressed audio, I cannot use TmpEngc directly because it doesn't work with compressed audio. Then, I tryed to extract audio with VirtualDub, but an error window appeared. What's the way to convert divx 5 to VCD? Thanks...
what did the error say
We were all NEWBIES once and the only stupid question is the one that's not asked? -
The message says:
'VirtualDub has detected an improper VBR audio encoding in the source AVI file and will rewrite the audio header with standard CBR values during processing for better compatibility. This may introduce up to 82834 ms of skew from the video stream. If this is un acceptable, decompress the 'entire' audio stream to an uncompressed WAV file and recompress with a constant bitrate encoder. (bitrate: 126.5+- 26.6 kbps)'
What's the solution? Have I to decompress and recompress? What program may I use to?
Thanks...
MKV stream extraction causing audio sync problems
By PlanetIndigo in forum Video ConversionReplies: 18Last Post: 29th May 2011, 23:07 -
Audio extraction from DVD using VirtualDubMod
By Ogilvy in forum AudioReplies: 4Last Post: 29th Mar 2010, 16:56 -
MKV chapter file extraction problems
By ikarishinji41 in forum EditingReplies: 1Last Post: 22nd Mar 2010, 12:03 -
MP4 Audio Extraction
By neumannu47 in forum Video ConversionReplies: 2Last Post: 28th Aug 2008, 20:17 -
5.1 audio channel extraction
By efiste2 in forum AudioReplies: 3Last Post: 15th Sep 2007, 05:05
