I've been using the same method over and over again and suddenly it gives he same error in the same timespot when converting DV file to DVD.
Workflow is the same, put minidV tape in VCR copy to DV-AVI, put to AVS convert to DVD and suddenly it repeats the same error in Audio part, where it says that audio duration is sorter than expected. All other programs do not intefere, the disk is literally ot used for anything, since it's not OS disk. Retransfered tape, still the same error.
Audio software used inside AVS2DVD is ffmpeg.
The files are standard 30 to 90 minutes DV files.
Results 1 to 19 of 19
Something about the file? The log clearly states that when processed, the audio is shorter than the video - the log gives the exact
times that it found.
Open this clip in Virtualdub2 and select File/Save WAV and write it out. Check the running time and compare to the A2D log.
If the length agrees with video, use this in your A2D project instead of the original audio from the video clipLast edited by davexnet; 28th Feb 2019 at 23:54.
The file is a straight from DV tape transfer the audio in the file is fine, when played with any meda player. And the same workflow never returned any errors.
I'll try first with other audio processing options, if all fail, I will have to do it that way...Last edited by SF01; 28th Feb 2019 at 12:22. Reason: typos
All options of audio processing give the same result, the time at which the stop appear is constant in all variants. The extraction and switching of audio track helped. But it's still peculiar why this problem occurs in the first palce. I have transffered hundreds of DV tapes to PC and to DVD with AVS and it never happeed, unless I stopped converision manually.
From the log:
<28.02.2019 18:01:23>
START AUDIO DEMUXING OPERATIONS (Track 1)
FFmpeg Parameters: -i "K:\Scenalyzer\604103738 - VHS-miniDV\DV'20050625 17.19.01.avi" -c:a copy -vn -sn -y "C:\Users\HP\Videos\20050625 17.19.01_DV'20050625 17.19.01_1.ToFix.wav"
<28.02.2019 18:01:31>
END AUDIO DEMUXING OPERATIONS (Track 1)
Created File: C:\Users\HP\Videos\20050625 17.19.01_DV'20050625 17.19.01_1.wav (840,3 MB)
Output Audio Info: PCM - 1536 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 1:16:29 hours (0 ms delay)
As you can see, it is ffmpeg extracting the audio giving the wrong length. The video was 1:22 but the audio 1:16.
Perhaps download a newer ffmpeg and replace the version a2d uses. See if it makes any difference.
The version used in A2d appears to be from 2014 -
Now the error appears immidiately with video encoding saying that video is shorter (00:00:00) than expected...
Manolito also says this in the link he provided above:
The latest and highly recommended version which works under Win XP and does not require to modify the "PATH" variable is this one from July 2016 by rogerdpack:
https://sourceforge.net/projects/ffm...e.zip/download
Give that version a try. If it still fails post the log again -
Well, that changes the game...
I'll then download the 32bit July 2016 version and put it in the AVS folder... -
Provide a source file that exhibits the problem and I'll take a look
Avidemux to trim commercials: output has shorter audio stream than video
By MGRV in forum EditingReplies: 5Last Post: 13th Feb 2019, 10:28 -
Interlaced Audio Duration Longer than Video Duration (lip-sync issue)
By senlab in forum Video ConversionReplies: 7Last Post: 27th Aug 2018, 15:36 -
When I cut/convert a .mpg file the audio is shorter than the video?
By Whitezombie455 in forum EditingReplies: 7Last Post: 7th Feb 2015, 21:57 -
MKV through AVS2DVD, no audio
By jnojr in forum Authoring (DVD)Replies: 1Last Post: 2nd Jan 2015, 15:26 -
Shorter Audio Stream = Delay?
By Djard in forum AudioReplies: 8Last Post: 12th Oct 2014, 12:31
