I'm curious if there's a way I can capture these tapes without converting the signal? Perhaps less quality lost. Using a DRM ES25 for pass through TBC
The VC500 handles PAL. Not sure about SECAM; Diamond does not mention it. You'll have to leave out the ES25, which is NTSC only.
AviSource("C:\Users\User\Desktop\believe.avi")
AssumeTFF
Trim(last, 205, 5945)
TFM.TDecimate()
Normalize(last, 0.98)
fadein(last, 50)
fadeout(last, 50)
ConvertToRGB32("rec601", interlaced=false)
My script so far. Should I deinterlace first? It gets a little confusing. I'm playing a PAL tape converted to NTSC (or however its done internally with the AGW1) and capturing with NTSC settings in VC500 so my frame rate is 29.97 and 720x480 -
As of now capturing the converted PAL tape with NTSC settings, I have what looks like 2 interlaced frames followed by 1 progressive looking frame.
Got a new Diamond VC500 but ...
By ksor in forum Newbie / General discussionsReplies: 6Last Post: 6th Feb 2019, 16:44 -
about a PAL / Secam / Mesecam vcr-dvd combo
By glitch in forum Capturing and VCRReplies: 9Last Post: 28th Jan 2019, 09:20 -
Is it true all PAL VCRs can play NTSC, PAL, SECAM tapes?
By digicube in forum Capturing and VCRReplies: 26Last Post: 16th Sep 2017, 10:20 -
How to tell a PAL and SECAM VHS signal apart?
By digicube in forum Capturing and VCRReplies: 20Last Post: 9th Feb 2017, 14:40 -
Panasonic dmr-e100h & panasonic dmr e700bd recorders - disc release problem
By nanirdjeff in forum DVD & Blu-ray RecordersReplies: 1Last Post: 5th Apr 2015, 12:59
