Hello!
I want to know how to remove or at least to decrease background noise for this AC3 sample, thanks!![]()
IMHO this is very difficult case, seem to be partially processed, lossy compressed, noise is periodical type (burst type) probably related to HW (tape, recording) limitations. You could blindly separate low frequency part and try to process it but you need really adaptive approach.
Fastest way to deal with problem is probably high pass filter around 125Hz, also there is not much over 9000Hz so it can be safely removed.
With low pass filter you may try to analyse audio to search for periodicity... try to remove it and later combine recovered low signal with remaining part (filter signal in different bands). -
Sounds like noise generated by a bad circuit board component. I would use the noise reduction filter in Adobe Audition and probably a gate as well. There will still be fuzz under the spoken syllables.
This can be related to way how audio and picture is stored on cinema tape, perhaps recording from different projector (poor man duplicator) - almost sure it will have 24Hz and related harmonics combined together with overall hum and distortions... (perhaps also other projector sound like Maltese cross mechanism so twice combined as probably both unsynchronised).
Quick and dirty, Dialogue de-noise module in Izotope RX 3
Audio in Aegisub has louder background noise than voice than video players
By xiiliea in forum SubtitleReplies: 1Last Post: 22nd Dec 2018, 14:44 -
Green Screen leaves background noise
By Rande in forum Newbie / General discussionsReplies: 5Last Post: 17th Oct 2016, 18:15 -
Sennheiser ew100 picked up noise from interview background
By AAC in forum AudioReplies: 3Last Post: 17th Sep 2015, 08:26 -
filtering heavy background noise - suggestions?
By zee944 in forum AudioReplies: 3Last Post: 5th Jun 2015, 22:20 -
Remove background sound of audio
By kasda in forum AudioReplies: 7Last Post: 9th Mar 2015, 16:35
