Hi ..and thanks for having me on the forum..I joined because my pioneer dv400v suddenly stopped working!! Had this model for quite a long time (very expensive then) and it has never been used much.We used it last about 2 months ago but now once its taken the dvd in it just says”loading” and thats it.Obviously tried good dvd’s..nothing.Can anyone suggest anything ..I’d hate to bin it..thanks rick
Sounds like you need to pull the cover(s) off and do a visual inspection and possible cleaning or lubrication.
If the machine is very old or not much used, the rubber drive discs or rubber belts may be hardened and slipping.
You might do an on-line search for a repair manual. I see a few listed.
But others here may have better information. And welcome to our forums.
Format of Pioneer recordings Pioneer 433H ...
By Pioneer in forum Newbie / General discussionsReplies: 4Last Post: 20th Apr 2017, 17:40 -
Pioneer Laser cleaning
By XploRa1 in forum DVD & Blu-ray RecordersReplies: 17Last Post: 5th Mar 2015, 14:11 -
Pioneer BDR-206D?
By NLP in forum DVD & Blu-ray WritersReplies: 11Last Post: 28th Sep 2014, 02:08 -
Pioneer dv 2242
By brisbane boy in forum Newbie / General discussionsReplies: 1Last Post: 7th Aug 2014, 21:47 -
Pioneer HTZ121DVD
By d_unbeliever in forum DVD & Blu-ray PlayersReplies: 5Last Post: 31st Mar 2014, 00:10
