I downloaded VCDeasy and tried to use it but it didn't work, there was some problem with my ASPI layer.
After upgrading my ASPI layer via Adaptec's upgrade package (v4.70), I tried VCDeasy again, but it still didn't work. "Fine", I thought, "I can live without making VCDs," and uninstalled it. Later that day, I tried to use CDEX to rip some CDs but got an error message saying that my ASPI layer wasn't working/installed correctly. Also, Windows Media Player can't read in digital mode anymore.
Is there any way to "downgrade" to an older ASPI layer?
Or could it be that I just messed up the installation of the new ASPI layer? On the website it says to unzip it to "C:\adaptec\aspi" but I don't have that directory. So if I did mess up, where do I put the new ASPI files?
PLEASE HELP A NEWBIE!!
do a search for a application on your system called "aspichk.exe" If this program says that you have probems with your aspi configuration, do a search on google for something called force aspi, this will force the aspi layers to update, even if adaptec says you can't
Insignia NS-WBRDVD3 downgrade for region free?
By menash23 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Jan 2012, 22:05 -
Downgrade from 1080p to 720p
By Izikd in forum Video ConversionReplies: 2Last Post: 24th Feb 2009, 06:30 -
Vista to XP downgrade: SATA question
By vid83 in forum ComputerReplies: 44Last Post: 19th Feb 2009, 19:51 -
Advice on how to downgrade the audio bitrate of a MOV file with AC-3 audio.
By InsanelyOne in forum MacReplies: 15Last Post: 13th May 2008, 22:40 -
Downgrade your PSP to version 1.5 using your PSP battery
By chrise in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2007, 08:27
