The MAGNAVOX513 DVD recorder suddenly will not dub HDD to DVD in HQ. I have REC MODE set to SP (2 HR) as I always do. I use SETUP but after I select the two (1 hr each) titles for dubbing, the MAG is setting SP as it should - but is turning off HQ. It then dubs the title in real time (displaying the recording as it dubs it). I can't figure out what I mistakenly changed to make this happen instead of the fast (HQ) dubs it's always done.
Any help will be most appreciated.
Thank you.
	The only time I have seen dubbing become a real-time process is when the DVD doesn't have enough space left to store the recording in its original quality. If that does not apply in your situation, then I have no alternative explanation for your problem.
 Sorry for the delay in responding. I didn't see your post when you made it because of a 30-hour power outage.Ignore list: hello_hello, tried, TechLord, Snoopy329
	Thank you usually_quiet for your post. I don't remember the details now but it is quite possible that this is the explanation for what happened. I seem to recall this was something about the remaining capacity of the DVD that was wrong (showing less than it actually had).
 (Sorry for the delay in reading your post but I had to move out for a while because of boiler issue)
  Audio Dubbing on DVRaptor RT2By mike6haywood in forum AudioReplies: 1Last Post: 19th Apr 2017, 14:48
  Dubbing music onto DVCAM tapeBy mike6haywood in forum AudioReplies: 2Last Post: 18th Apr 2017, 12:03
  Need Assistance With Dubbing on Mag557 RecorderBy Novice20 in forum Newbie / General discussionsReplies: 28Last Post: 2nd Feb 2017, 20:44
  can I remove dubbing on an avi file?By pattirose in forum Newbie / General discussionsReplies: 29Last Post: 15th Sep 2015, 12:42
  Dubbing advice for bereaved non-techie momBy LindaSB in forum Newbie / General discussionsReplies: 13Last Post: 30th Nov 2014, 15:11
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
